JuanCarlos
Vectorworks, Inc Employee
    141
Reputation
72 Excellent
2 Followers
Personal Information
  • Occupation
    Architect
  • Homepage
    www.vectorworks.net
  • Location
    United States
Contact Info
  • Skype
    jcf4vw
Recent Profile Visitors
3,100 profile views
  1. If you do not want to mess with the user origin here is where you correct the rotation angle,
  2. You will need to include COBie in your Views
  3. Are you selecting the COBie export option? HTH
  4. For the Qty you will use =COUNT(Criteria) and for Percentage well that would be some percentage math from the results in column B https://app-help.vectorworks.net/2025/eng/VW2025_Guide/Worksheets/Entering_formulas_in_worksheet_cells.htm?rhsearch=worksheets&rhhlterm=worksheet HTH
  5. Just wanted to let you know that the Stair is in the Roadmap, it was an oversight! https://www.vectorworks.net/en-US/public-roadmap?url=-486 Now would be a good time to add any particular wishes to the Stair card(s) HTH
  6. As Pat mentioned C1 has to be a number, then you can try this =IFS(C1<=1500, '5', C1>=5000, '9',(C1>1500) & (C1<5000), '8') HTH
  7. In the Window settings, General pane, Configuration setting select the "Custom..." option, then play with with the Custom Configuration Options. HTH
  8. With the Custom Stair selected in a 3D view <Control U> (PC) <Command U> (Mac) > OK converts to 3d objects Extrudes and 3D Polygons, this allows to edit the individual pieces. HTH
  9. This Is the closest I could get using the old Custom Stair, from here you can ungroup and finish modeling it. HTH squared spiral staircase.vwx
  10. @CAD Cadet Glad it's working for you, soon it will be much better https://www.vectorworks.net/en-US/public-roadmap !
  11. @Tom W. On the bottom right set the height and width to 0 Window Custom.vwx
  12. @CAD Cadet It is possible, it's just not the friendliest option! In the Window Tool General > Custom Configuration Options. But don't loose hope, we are working on it https://www.vectorworks.net/en-US/public-roadmap Window 2 top awnings.pdf
