When you are creating/moving a new object, the data bar pop up sometimes stops functioning?
E.g. If I draw a line, and then press tab to fill in the distance dimension, I can't type more than the first digit. I can tab between the angle, and other info boxes etc. But I can't enter more than one digit. I can't work out the scenario that is causing this, but I'll keep an eye out.
The only way to fix it is restarting VW, but it can happen quite frequently.
Jonny S
Hi,
19 answers to this question
