Patrick Fritsch
    661
Reputation
106 Spectacular
1 Follower
Personal Information
  • Occupation
    Arch. Tech. / Certified Passive House Designer
  • Homepage
    www.fpwi.ca
  • Location
    Canada
Recent Profile Visitors
5,737 profile views
  1. Can someone enlighten me on this "Phase" drop down box in the "Create Detail Viewport" dialog box? I did not find any mention of it in the help pages nor online?
  2. ALL CAPS **** THIS IS A VECTORWORKS BUG **** THIS IS THE ONLY SOFTWARE THAT IS HAVING THIS ISSUE ON MANY OF OUR COMPUTERS WHEN PROPERLY PROGRAMMED A SOFTWARE SHOULD BE ABLE TO SELECT AN AVAILABLE PORT PLEASE STOP IGNORING US TROUBLED USERS...OH AND HAPPY NEW YEAR!
  3. This process crashes in VW 2026 sp2 as you do the last step to edit slope
  4. I feel your pain, still dealing with this. My next step that I was thinking of trying is to temporarily disable all startup apps and if that works re-enable them one at a time until I find the culprit...hopefully eventually I will have some time.
  5. CIRCUITING TOOL IN MEP DOES NOT WORK IN 2025!...NOT THAT IT EVER DID ANYHOW. STOP ADDING AND FIX WHAT YOU GOT.
  6. @RDS Casa ... No still happening here w/ latest Sp! they are probably still assuming it's a Windows OS problem.
  7. Already a better explanation Nokolay...but....this still needs to be more flexible...a lot of wasted time doing something SO tedious.
  8. @JuanP This is a VW bug and should be looked into seriously, it's depriving us of productivity.
  9. Same server busy pop up all the time with VW 2024, only program causing this on my machine...it's definitely a VW bug in file management....they will maybe fix in 10 years...
  10. @sbarrett @_James James is correct, top north of page should be indicating North. Can you fix this @sbarrett ? Thanks
  11. Well I did not get any update from @sbarrett to fix this but can share that I got this Marionette working after copying the files from VW 2023 install folder to the VW 2024 folder. Simply copy/paste all files in C:\Users\patri\AppData\Roaming\Nemetschek\Vectorworks\2024\Python Externals Obviously your users sub-folder (in bold above) will be different.
  12. @sbarrett Cannot use in VW 2024, get message that it cannot download Python GEOPY...Can we just make this built into VW for upcoming revisions, everyone is doing solar studies and heliodon is not sufficient on it own to graphically show sun path to clients...even better would be a 3D version of this like Revit has.
  13. Not a great productive experience for me either...it's the little things in a UX that make it or break it. Like this tool set pallet not having a clear horizontal division with the individual tools, my eyes are always trying to find where one section/part/group ends and another starts. Sorry but it's a fail for UX on the productivity front. To not just whine, I recommend taking a look a clear UI like Modo, dark monochrome'ish mode w/ clear separation of icons and clear highlight of active icons/modes. I also like that they give the shortcut key on icons when possible...the eye is quicker than the mouse young kitty!
  14. Any suggestions on how to fix this, Path site modifiers have no thickness like the Road shown beyond so the Render texture is coincident with the DTM....
  15. Yes but in the name of efficiency, please. We can do it with the Grid line tool so why not with the Elevation Benchmark tool, seems like a functionality oversight.
