2,730 -
Everything posted by rDesign
Rendering differences in VW2023 on Windows and VW2024 on Mac
rDesign replied to MGuilfoile's question in Troubleshooting
As Zoomer said, this is most likely a function of the difference between how MacOS and Windows OS handle color profiles / calibration. Have you tried to see if it matters how you created the PDF? Publish or Export to PDF vs Print -> Save As PDF ? ColorSync is the application that manages color profiles on MacOS, I don’t know what manages it on Windows. A google search for “pdf different color on mac vs windows” gives some results which might lead you to a solution. -
There’s a few older threads on this topic found by searching for ‘curved monitor’. Here’s a link to one:
Floor line in the middle of the wall in section.
rDesign replied to Leandrovsk's topic in Architecture
If one was bothered enough by this line, another option would be to draw a white 2D polygon / rectangle ‘wipe-out’ over that line as a SLVP Annotation. Just have to remember to move the Annotation if you move the wall. -
@zack310 a couple of recent related threads linked below, found by searching for “pdf size”. Others have experienced this as well, but it is a long standing issue with PDF files made by Vw, it is not an issue limited to just Vw2024. If you are getting large PDFs, it is always recommended to run your PDF through a ‘pdf squeezing’ app or website, a few suggestions are provided in the linked threads.
Maybe someone else knows of a command to ‘fix’ this, but I do not know of one. I do know that removing Wall Breaks will not do what you are hoping it will do, as you have already discovered. I just think this is how it is. @JuanP — any suggestions?
What scale are you viewing this at? I don’t think that something as hair-line thin as this would show up on a printed PDF for a typically scaled floor plan. This may just be an artifact of the PDF creation of the solid fill on your walls and there may not be much you can do about it. If you really want to get rid of this — my suggestion would be to switch to a non-solid wall fill, like a diagonal hatch.
Snapping stops working when editing deeply nested objects.
rDesign replied to Bruce Kieffer's question in Troubleshooting
Bruce, no need to send me a file — I’ll take your word for it. I don’t work at Vw, if that’s what you’re thinking. Sending me your file will not help get it fixed. 😉 -
1) It seems like you are trying to add an image to an extruded 3D object using the Attributes palette and adding a Fill to the 3D Object, correct? The Image Fill attributes controlled by the Attributes palette only work on 2D objects, not 3D objects. 2) Same goes for when you tried to apply an image to the Fill of your Class. If you were working with 2D Objects, this could work, but not 3D. To add an image to a 3D object you need to create a Renderworks Texture. Vw2024 Help File — Creating Textures I would also recommend looking at the Vw University training portal for the basics on how Vw works, as it often works differently from the way that other 3D applications might work. Here is a link to a 4min course titled ‘Apply Object Texture’: https://university.vectorworks.net/course/view.php?id=1440
macOS v Windows 11 - 2024 Startup Time
rDesign replied to Charlie Winter's topic in General Discussion
There have been some other threads about slow startups with Vw2024, supposedly the first time opening after installation is the slowest, but it should speed up after that. -
@Bruce Kieffer If you are a Service Select member, you can send an email to premiumtech@vectorworks.net and you will get a confirmation automatically with a case number. -
At the bottom of every page in the Vw 2024 Help file (and all earlier editions) is a link which says ‘Was this page helpful?’ When you click on that link, you are taken to the general VW Customer Support Page on the user portal, leaving you without a clue about where you are to let someone know if the help page was helpful or not. For example, after reading a thread on the user forum I wanted to see if the Help File page on Creating Site Models from Source Data said that you should always be in Top / Plan view when you run this command — because if you are in a 3D view your Site Model will be created way off center. The help page says nothing about this, so I wanted to let someone at Vw know that this page was ‘not helpful’. REQUEST: The expected behavior for wanting to provide feedback on a specific page in the help file would be: after clicking that ‘Was this page helpful?’ link to be provided with a form that has the page URL and page title already filled out so you can easily provide feedback on that specific page. The way it is right now is anything but helpful.
If you activate the Data Bar after you start drawing the Wall by pressing the Tab key, then you can further tab over to the Length field and input the length there, or by inputting the Delta X / Y of the Wall from the starting point. Note that depending on how your wall is set up, the length you enter might be measured from a different point than you are expecting. Ex: the wall might be measured along the center line of the wall, when you really want it measured along the inside face. Always confirm your drawn wall lengths by measuring them with the Dimension tool. Vw2024 Help File — Using the Data Bar Vw2024 Help File — Drawing with the Data Bar
You could also create a flattened vertical section viewport on a Design Layer, drawing your 2D linework on top of the flattened section. Link to Vw2024 Help File page on Creating a Vertical Section Viewport Personally, I typically put my 2D linework in a the annotations of a SL Section Viewport.
Constant crashing and computer freezing when zooming in or out.
rDesign replied to Kevin K's question in Troubleshooting
What are the hardware specs on your Mac? I have read other user reports on the forum about recent releases of Vw (particularly 2024) not releasing RAM properly (on both Intel and M-series), so if your Mac was underpowered (not enough RAM) I would think it could lead to this behavior. Link to KB article on Vectorworks 2024 System Requirements -
I have not opened your file, but the issue is that you are using Walls with components which are bounded to a Story that does not exist in that level. Deleting Stories is the opposite of what you need to do to fix this. To fix it you have to do what Tom W said..
Service Select Increase is Crazy - Not Impressed
rDesign replied to Kevin McAllister's topic in General Discussion
As a user holding off on yet to use Vw2024 for billable work — partially due to the number of new bugs introduced in Vw2024, not to mention the number of still unresolved old bugs — it is hard to stomach this annual percent increase of ~50%. Where is the added $$$ going? If you spend any amount of time on the user forums and read users’ posts about their experience with Vw2024, it doesn’t feel like it’s going towards quality control. -
FYI - You can remove a ‘thumbs-down’ reaction on someone’s post that you later regret by clicking on the little black circle with an ‘X’ next to your reaction’. It will remove the reaction. -
Fastener tool VW 24. Inserting at offset Location
rDesign replied to BartHays's question in Troubleshooting
No, they seem to place correctly for me. Tried on a Design Layer, Sheet Layer and inside a SLVP Annotations. Tried both 2D & 3D. -
Ability to bookmark specific posts within the forum software
rDesign replied to Christiaan's question in Forum Feedback
Bumping this topic, it would really be great to have Bookmarks for topics on the forum. The link that Christiaan posted is now dead — but I found a new link for it, or at least another possible third-party plug-in. https://www.ic-essentials.com/files/file/31-bookmarks/ -
Fencing Tool - Anyone with Full Instructions
rDesign replied to Michael Siggers's topic in General Discussion
Coffee Break - Vectorworks 2024 New Automated Fence Tool https://university.vectorworks.net/course/view.php?id=2926 I have found that if you just try and jump into any tool in VW thinking that you can just figure it out, you will have nothing but frustration. I would recommend the first step in trying to learn any new tool in Vw is to first search on the Vw University portal for any training material. It will be time well spent. -
Incompatible Plug-ins Report: MaxonDocument Builder // MaxonRenderDevice
rDesign replied to High_Viz's question in Troubleshooting
I don't have any insight into those two plugins @JuanP - any thoughts? You probably will need to contact Tech Support, but first you could try repairing the installation using the Vectorworks 2024 Updater application. Click 'Advanced Options' at the upper right corner and then 'Repair'.- 20 replies
- 1
- vectworkworks
- graphics
(and 2 more)
Tagged with:
Creating a 'Site Model' Class: States already existing
The class Site-DTM-Modifier, which is automatically created the first time you create a Site Modifier, is a special class in that any NURBS or 3D poly that you put in this Class can be used as a Site Modifier.. -
You could also try using CloudCompare to subsample your original point cloud to have a max of 100 million points.
Replace Symbol Window Bigger than screen
rDesign replied to ratherfishing's question in Troubleshooting
Yes, when you reset your Vw preferences it will request re-activation. There is a long-standing wishlist request (from 2014) for an online portal / means to deactivate a license, and not have to wait for Vw Tech support to manually reset it. Feel free to follow the link below and go upvote the request. One would expect that the Vw Customer Portal would show the current number of license / seat activations, but it does not appear to. -
Maxon is the company that makes CineRender and Redshift, which are the two primary rendering engines in Vw. Your screenshot doesn’t show the names of the offending plug-ins. If you grab / drag the divider to the right of the Path so that the plug-in names are shown, what does it say?- 20 replies
- vectworkworks
- graphics
(and 2 more)
Tagged with:
