Rishie
Content Count
44 -
Community Reputation
1 NeutralAbout Rishie
Rank
Greenhorn
Personal Information
Location
India
Recent Profile Visitors
918 profile views
Thank you very much Tom and Andy. Much Appreciated!!!
Thanks @Andy Broomell I was able to create a tile, but unfortunately I'm unable to assign it as a surface hatch to a texture. @Christian Fekete Thanks for asking it. I want my roof to show in exterior elevation (hidden line rendering) with a hatch pattern (Pen style to have pattern not solid). To be very clear, I've attached a VW file (V 2020) and PDF to show want I'm trying to achieve. Please take a look at it. Would be grateful for your help. Thank you, Rishie Query with Surface Hatch V 2020.pdf Query with Surface Hatch V 2020.vwx
How to align wall's surface hatch while generating exterior elevation
Rishie replied to Rishie's topic in Architecture
Thank you very much Joe it worked -
Can we set a pattern as a pen style for a hatch? I tried a few times but could only manage to get a solid color not a hatch pattern as a pen style while creating hatch. Thanks, Rishie
Construction Documents Assistance / Outsourcing
Rishie replied to kp2architects's topic in General Discussion
Hi Kenton Peter, We undertake VW outsourcing jobs (Drafting, Modelling, etc.,) and we are Vectorworks and Vectorworks only from India. To Learn More about us https://vectorworksoutsourceindia.com. Thank you, Rishie. -
Hi, We undertake VW outsourcing jobs(Drafting, 3D Modelling, etc.,) and we are Vectorworks and Vectorworks only from India. To Learn More about us https://vectorworksoutsourceindia.com. Thank you, Rishie
Disappearing Walls (also slabs sometimes)
Rishie replied to Amorphous - Julian's question in Troubleshooting
I have also noticed that the wall object sometimes disappears after inserting the slab through the inner boundary mode. The wall appears in 2D but not in 3D. I am only able to select it in 2D. When I move it in 2D or replace the wall style it shows up in 3D. I am using VW 2019 SP4 in Mac OS 10.14.6 -
Connect between design layers and story levels disconnects
Rishie posted a question in Troubleshooting
Sometimes, while working in design layer the connect between the story levels and design layers removes automatically and I can’t find when this change is happening and how is this happening. I have encountered it two times, first I thought I would have missed something and when the same happens again I can’t find when and why this is happing, but this makes things strange. I need to manually connect all the design layers once again to its story level. Have you ever experienced this? -
Space tool width by height or height by width
Rishie replied to Josh NZ's topic in General Discussion
Could we calculate (X direction x Y direction) ? other then (length x width) (or) (width x length), calculate room dimension taken as (length x width) which is longer side of rectangle x shorter side of rectangle- 7 replies
- space
- space tool
(and 1 more)
Tagged with:
Hello guys, I am trying hard for creating a lighted candle, but can't find the appropriate setting for light and rendering. could anyone out here help me in achieving it. I had attached my file for your reference. Candle.vwx Candle.vwx
I have tried creating a fabric texture by importing a image but i can't find the perfect setting for it. while rendering i can't active what is needed? i have attached the image of the fabric. please do suggest a setting for it.
Exactly, Gadzooks You are correct
Hi guys, How to fit corner window in wall which is jointed using capped wall joint mode? While inserting, it is not fitting properly. Could anyone help in fixing it For clarity i attach few screenshots and Vectorworks file corner window.vwx
