388 -
Everything posted by Diego Rodrigo - RV
Yes, I'm afraid it was created with an illegal version...
Hi Stafano, I've managed to convert the file to DWG using th OzCad MiniCad translator, do you still need it?
Background Viewport Update
Diego Rodrigo - RV replied to Diego Rodrigo - RV's question in Wishlist - Feature and Content Requests
Yes, maybe a preference to enable updates when they are enough, I don't konw, enough processor cores unused or, like when we do automatic backup saves, every 10 minutes or so. -
Diego Rodrigo - RV posted a question in Wishlist - Feature and Content Requests
When you update something in the model, the viewports remain outdated, but you don't update right away, you just keep working until, at some point, you need to review the sheets with the viewports, right? Many of us have good enough machines, so it could be possible that the unused hardware resources could be used in the background to update the viewports while we work in the model? -
I've use a lot of concrete stairs and there is no way to obtain the volume, m3 or cubic feet, of a stair, other than rebuild the stair using extrudes or converting to a generic solid and using the 3D properties, but you canont put that data on a worksheet, and in the process you destroy the parametric the stair, and if you change the model you have to redo the stairs, all of them.
Hi everyone, I'm trying to export to WebView a small project, the file upload to the Vectorworks server, but when is goinf to open the browser to show the model gives me a script error. And I'm unable to view the model. I've been using webview for other projects and never had an issue. I'm using Vectorworks 2017 macOS Sierra Safari as default browser..
Another option is Modelo https://modelo.io
3D Clip Cube
Diego Rodrigo - RV replied to Jim Smith's question in Wishlist - Feature and Content Requests
I'll give it a try!!!, Nice Tip! -
3D Clip Cube
I really would like to create a perspective 3D viewport of the clip cube to insert in the sheets, now you have to "cheat" , you export the clip cube as an image and imported back into the sheet layer, but if there are changes in the model you have do it all over again -
Materials / Texture option
Diego Rodrigo - RV replied to digitalcarbon's question in Wishlist - Feature and Content Requests
It's a great idea, one could do a fast checkup how the works in the field are going on. -
Recommended file setup for large number of houses + site model
Diego Rodrigo - RV replied to Christiaan's topic in Workflows
The best way to do it, is using Design Layers Viewports and referencing, Set up a file with the site model and then create a Design Layer Viewport for the house, and duplicate the viewport in the correct places. -
thinking of upgrading to OS Sierra
Diego Rodrigo - RV replied to digitalcarbon's topic in General Discussion
I've tested and Vectorworks render much slower in Sierra than in El Capitan, but I tested only the spanish version -
Vectorworks 2017 File Won't Stay Minimized on Mac
Diego Rodrigo - RV replied to Kristin Fogarty-Yi's topic in Architecture
What SP are you running, I've just tested and Vectorworks minimizes correctly with several documents open. -
Hi, we also do Vectorworks outsourcing only, we are located in south america, https://resuelvectorworks.com/consultoria-bim/
For the cabinet in the corner is best to use the Corner Square Front type from the Style drop-down menu..
Trouble moving license to new machine
Diego Rodrigo - RV replied to Brookems's topic in General Discussion
So when I'm updating to a new machine, I'll have to buy a new license?!?!?! -
dRofus: Great news for Vectorworks users...?
Diego Rodrigo - RV replied to MRD Mark Ridgewell's topic in General Discussion
Not likekly to happen, because once Nemetschek buys a company, most of the time they let that company run independent from the others companies Nemetscheks owns, right now owns ArchiCAD also and AllPlan, and for example there is no plans to do a Mac version of AllPlan or of another windows centric software, like DDS CAD- 2 replies
- vw2017
- nemetschek
(and 1 more)
Tagged with:
Looks great! kudos!
Yes, even in viewports, where straight walls looks like one wall, round walls don't "join"
Obtain the volume for a concrete Stair
Diego Rodrigo - RV replied to Diego Rodrigo - RV's topic in Architecture
Yes, I've got similar results, my thinking is, if you ungroup the stair is basically a Mesh object, so I think the only way to obtain the volume would be to model the stairs with extrudes, too bad and time consuming... -
Is there a way to extract the volumen of a Stair? When I tried to do a Report or using a worksheet to obtain a volume, the result is always 0. Any ideas?
Construction Documents Assistance / Outsourcing
Diego Rodrigo - RV replied to kp2architects's topic in General Discussion
Greetings, I've an outsourcing studio for Vectorworks projects, if you need I'll be glad to help you. Diego
