223 -
Reputation
48 GreatPersonal Information
Occupation
Interior design & architecture
Homepage
www.markridgewelldesign.co.uk
Location
United Kingdom
Recent Profile Visitors
1,910 profile views
Anyone using this successfully; sharing links with Clients?
Hi, Here's a diagram I produced a while back (as a piece of research for other interests) edited to illustrate the 'customer/ specifier' journey to source product using a 3d/ BIM type workflow when you have in mind either the product or supplier you want to use (a bit different if you haven't got a product or specifier in mind). Certainly not comprehensive, but possibly of use/ interest to someone... 190513_Forum_Bimmble_graphics_specifier.pdf
Yes to both. Hyperlink function is ok for some things but in OIP as Markdd suggests...similar function to Hyperlink (possibly even simpler) to keep info. off drawing. So for example, if I have a product in mind and can't get a 3d asset for it, and haven't time to draw it I can add a link (maybe more accurate to call it a 'book mark') into OIP without the need to control the location of a load of text over my drawings, for example....
Yes, and they're very helpful. However, to create native/ optimised 3d VW assets on the scale that's needed, my feeling is that Manufacturers need to be engaged and willing, and content needs updating regularly. There are quite a few good 3d content platforms now, but where's the native 3d Vectorworks content on them...?
I'd like to quickly easily be able to add weblinks (which can be easily turned on and off) to any object within Vectorworks so that I can easily cross reference to Products/ finishes/ Materials. Ideally, it would be a box visible on the 'object info./ shape palette'. Ideally, it would be integral to VW interface rather than having to add it as'record' for every item?! Anyone else think this would be useful?
There are a few decent 3d WC pans (Ideal Standard) in VW but quality varies. Pick what you want and email VW and IS if it's not there or doesn't work. Make it known that you want to specify their (whoever is your chosen Manufacturer) products and need native 3d content to fit your workflow...it's in their interest to support your 3d asset needs (ie. native/ optimised Vectorworks content) if they want your custom. Why should you have to spend your precious time modelling or optimising their sanitaryware 3d assets only for the next specifier to come along and have to do the same again?! Isn't 3d/ BIM supposed to save time, be more accurate?! My feeling is that Vectorworks needs to up it's profile so that Manufacturers provide native Vectorworks 3d assets as a default (rather than the typical response.. 'Vectorworks...is that like Revit?)
Interior Elevation Marker line
MRD Mark Ridgewell replied to MRD Mark Ridgewell's topic in General Discussion
UPDATE: machine restart has restored normal function of this tool -
Ps - how do you delete a duplicate post? -
Have set up Interior Elevations, but they run through 3d objects. Have gone back to design layer to adjust section line. Usually, it's an easy operation to add vertices to the section line marker and make a staggered section line. Only try as I may, it doesn't seem to work. Any ideas?! If I click on the section line once (on design layer) I get blue handles. Twice, I get reshape tool (add vertex mode and move 'reshape handles') neither of which seem to do anything, as no 'reshape handles' are present...? It would be great to have some kind of a tool whereby if the line runs through 3d objects they get hidden
possible to import 3D Objects made with Blender into VW?
MRD Mark Ridgewell replied to Phileas's topic in General Discussion
interested to hear how you get on! -
You've most likely solved thie by now but if not...go to the marker on the design layer and change the two variables highlighted in the attached image. I hope you don't mind if I 'hijack' your post on a few interior elevation related comments/ queries which I wonder if anyone(/VW) has any view on/ remedy to. 1) VW default seems to be to generate a scale on the sheet layer elevation viewports (so you have to manually turn it of on each elevation on the sheet file if you don't want it to displayed - often the case for me). Is there another way? A tick box to turn this off early on in the process would save much editing of viewports. 2) The elevation marker is generated centrally justified (I'm yet to meet an architect/ designer places them that way - more usually left justified, sometimes right). Can this be set to default to the side? 3) The default elevation depth is very deep and in a large file can lead to lengthy waits while VW generates elevations(s). Can default be set to say, 1m, 5m 10m rather than what seems to currently be the depth of the building (through countless walls) to avoid the need to manually amend (by flipping between sheet and design layers)? All minor things in themselves, but add up to a considerable investment in time, especially when you have multiple 10-20 drawing sheets each with 4 elevations to set up!
Hi, Have you tried .obj export from Blender, then import into VW? Mark -
...an indication of turning circle may be useful for space planning purposes too!
