bc Posted November 15, 2019 Share Posted November 15, 2019 (edited) This is pretty annoying. Darn near impossible for me to select site model modifiers on a site model...even in wire frame. The model always takes priority. What is the best way to select site modifiers on a site model? Thank you. bc Edited November 15, 2019 by bc Quote Link to comment
E|FA Posted November 15, 2019 Share Posted November 15, 2019 Try Coincident Select: https://app-help.vectorworks.net/2020/eng/index.htm#t=VW2020_Guide%2FBasic1%2FCoincident_object_selection.htm Another option is to put site modifiers on a separate layer, but make sure "Use Site Modifiers on:" is configured properly in the Site Model Settings. 2 Quote Link to comment
twk Posted November 15, 2019 Share Posted November 15, 2019 (edited) We class our Site Model (Site-DTM-Main), then toggle that to grey when we need to manipulate other objects on the same layer as the site model. You are true that it is a pain that the Site Model takes precedence over any other object. Edited November 15, 2019 by twk Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted November 15, 2019 Vectorworks, Inc Employee Share Posted November 15, 2019 I recommend that you keep Site Modifiers on a separate layer, if not more than one separate layer. That means that you can easily control and select them, but also experiment with different design options. Within the Site Model Settings dialogue, if you set the Use Site Modifiers on option to Visible layers only (or there is also an option to choose specific layers that are able to update the model), you will find that you can apply different sets of modifiers to the site. It's also a great option for trouble-shooting. Quote Link to comment
bc Posted November 15, 2019 Author Share Posted November 15, 2019 All right! Thanks for all that everyone. I'll give it a go and try both methods. 1 Quote Link to comment
AlanW Posted November 16, 2019 Share Posted November 16, 2019 With nothing selected hold down the shift key and then cross over what you want. This way your first click will not select anything 1 Quote Link to comment
line-weight Posted November 16, 2019 Share Posted November 16, 2019 Selecting site modifiers is a pain. One simple thing to watch out for though - make sure you don't have the site model itself selected. If it's selected it's then impossible to select the site modifiers at all. This really confused me for some time. This behaviour is different to everywhere else in VW, where if one object is currently selected, it doesn't stop you from selecting something else instead. Quote Link to comment
vassen Posted January 16, 2020 Share Posted January 16, 2020 Don't know if you still having this issue. Press on "J" then click on the place where the site modifier is, a dialogue box should appear Quote Link to comment
