- 1
Flattening 3D facets to dimension each face of object?
Asked by
KyleBlasius
Asked by
KyleBlasius
7150 Riverwood Drive, Columbia, Maryland 21046, USA | Contact Us: 410-290-5114
© 2018 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
Hello,
I've searched the forums to no avail on this topic... several had promising leads but are ten years out of date, and suggested plug-ins that no longer work.
Is there a way to take a 3D facet - in this case, a triangle that I have extruded and then deformed to have a taper, meaning it's a simple four-sided facets (there are NO curves or rounded edges or anything, just the four solid surfaces) - and flatten it so that each side lays down correctly and keeps the correct proportions so that I can dimension it? The goal is to be able to cut out pieces to create dozens of different facets, but I need to lay out each side of each facet and dimension them correctly in order to do so.
I've played around with converting the objects to 2d/3d poly, NURBS surfaces, and several other things, but I just can't seem to get them to break apart into four distinct facets, and then flatten out while keeping their correct dimensions - they all just flatten relative to my screen plane which isn't helpful at all.
Any help on this matter is much appreciated. Thanks folks.
