Josh NZ Posted December 14, 2016 Share Posted December 14, 2016 I have made changes to the external trim of a window. I wish to apply these changes to the other windows in the job. I select the window, go into the Copy and Apply windoor setting palette. The copy from "selected windoor object" is not selectable. The other two options are from file default settings which is not applicable, the other option is from windoor symbol which is blank. Ideas? Quote Link to comment
AlanW Posted December 14, 2016 Share Posted December 14, 2016 Hi, If you have already selected the window you would only have the option to select the ones you need to copy your window item to. I think you need to now select which ones you want to apply the settings to on the right side. HTH Quote Link to comment
Itchy Posted December 14, 2016 Share Posted December 14, 2016 Sent Julian from Ozcad this a few weeks ago, sounds like it is going to be fixed in SP2. Quote Link to comment
Josh NZ Posted December 14, 2016 Author Share Posted December 14, 2016 (edited) Sadly I'm running SP2 and it's still occurring. Edited December 14, 2016 by Josh NZ Quote Link to comment
Itchy Posted December 14, 2016 Share Posted December 14, 2016 Just downloading the update now, I'll test at my end as well and follow up the email with Julian. Quote Link to comment
Josh NZ Posted December 14, 2016 Author Share Posted December 14, 2016 Great, thanks for the update Itchy. Quote Link to comment
Itchy Posted December 14, 2016 Share Posted December 14, 2016 Still persistent with SP2 for me, have emailed Julian and linked in this thread. Quote Link to comment
rDesign Posted December 16, 2016 Share Posted December 16, 2016 (edited) I don't know if this is what is going on with your Windoor issues, but occasionally I get similar blank drop-down selectors like you are experiencing — here is a recent example of when it happened to me using the Heliodon tool: It happens to me with a variety of tools which all appear to share the same style of pull-down selector, and the only way I can fix it is to Reset my Vectorworks User Preferences Folder Just a thought - perhaps that's what you're experiencing with Windoor, maybe it's a Vw problem not directly related to Windoor itself. Edited December 16, 2016 by rDesign Quote Link to comment
zoomer Posted December 16, 2016 Share Posted December 16, 2016 I had this in the past when I allowed myself to not "display default content" (As far as remember although I copied all VW ressources into my Workspace Folder (?)) Also I have that when I do not concentrate when "purging" my files, as Heliodon Symbol as well as it's ressources (same as for Image Props) will be selected for purging, although used. Maybe because all these Symbols are used/inserted as PlugIns only in the file. Quote Link to comment
Itchy Posted December 18, 2016 Share Posted December 18, 2016 I have heard back from Ozcad, there was a bug preventing this from working when one object was selected, and it now doesn't work with multiple objects as it became too difficult for it to figure out what the first object was. The workflow now if you want to copy is to select one, copy to defaults, select the others, copy from defaults. Megabits (Bill & Jeremy) should now have a copy of Windoor v22.0.4 1 Quote Link to comment
Josh NZ Posted December 18, 2016 Author Share Posted December 18, 2016 Thanks for that Itchy, will give that a try. Quote Link to comment
Jeremy Best Posted February 24, 2017 Share Posted February 24, 2017 For users of Vectorworks 2017 I would recommend watching the following video produced by OzCAD. With the introduction of Window Styles in Vectorworks 2017 the workflows with Windows, Doors and WinDoors has great new advantages. It seems to me the object-to-object copy/apply method has (by my reckoning) been superseded. Quote Link to comment
Markvl Posted February 24, 2017 Share Posted February 24, 2017 Windoor for the North American market please! Quote Link to comment
zoomer Posted February 24, 2017 Share Posted February 24, 2017 German Window and Doors please for the international market too Quote Link to comment
