ACrisford Posted September 9, 2015 Share Posted September 9, 2015 Hi, Im just a little lost about this, but if I use the 'Hide Objects' button, how do i unhide them afterwards? For instance, i want to hide the roof whilst I'm working on a floor plan, but i obviously still want the roof later on. Any idea how i can unhide the object later on? Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted September 9, 2015 Vectorworks, Inc Employee Share Posted September 9, 2015 This would be done normally with Classes or Layers, you can turn the visibility of them on and off much more easily than going object by object. You can also then use Saved Views to recall saved sets of visibilities for different portions of work or presentation. Quote Link to comment
VincentCuclair Posted September 9, 2015 Share Posted September 9, 2015 (edited) Andrew, sounds like you are used to Revit? In Vectorworks we show and hide classes in a more traditional fashion (like AutoCAD and ArchiCAD), through class settings. However if you would like a work flow more like Revits Temporary Hide I would suggest the Visibility Tool, basically you can hide/show objects in a similar class by clicking on them depending on what you have selected in the mode bar. If you would like to show(unhide) something that is hidden press the V key while the Visibility Tool is active to temporarally show hidden objects and click on the ones you want to show again after selecting the correct mode. Edited September 9, 2015 by Vincent C Quote Link to comment
ACrisford Posted September 10, 2015 Author Share Posted September 10, 2015 Thanks Vincent, Yes, i did use Revit for 2 years, but I've been using vector works for over 3 years, you'd think id be used to it by now lol.. Just figured if theres a hide objects button, it would make sense to be able to unhide it later. Anyway, you're help is much appreciated, should save me a lot of time in the future Quote Link to comment
Benson Shaw Posted September 10, 2015 Share Posted September 10, 2015 OK, I'm stumped. Ironically, I cannot find the Hide Objects button. There are loads of Vectorworks areas where I do not venture. Is this an OIP option for certain objects? A tool? a command? Vectorworks Help search finds no topic (But I'm going to nominate it for a topic if I ever find out what/where it is). Can anyone point me? Thanks -B Quote Link to comment
rDesign Posted September 10, 2015 Share Posted September 10, 2015 @Benson: I've been confused by this as well because as far as I know there is no 'Hide Objects' button, tool or command. I had assumed the original post was actually referring to the Visibility Tool > 'Invisible' mode which hides the clicked object’s class or layer. Quote Link to comment
AlanW Posted September 10, 2015 Share Posted September 10, 2015 Shortcut "v" on keyboard and mouse over to highlight then click to turn off and on. On basic OIP looks like an eye with arrow to left. Quote Link to comment
Kevin McAllister Posted September 10, 2015 Share Posted September 10, 2015 So I discovered it is actually possible to Hide and Show individual objects. I was pretty sure you could and I just did a test in Vectorscript. There isn't really any documentation if you don't have any VS experience ( see http://developer.vectorworks.net/index.php/VS:Hide ) but with messing around I was able to made a pair of scripts - one to hide an object named "Box" and another to show all objects that aren't currently visible. Pretty rudimentary but possible. I've attached a file containing the scripts. I may play with this further as the Show and Hide commands are some of my favorites in Rhino. They are very useful for isolation when modelling. Kevin Quote Link to comment
Pat Stanford Posted September 10, 2015 Share Posted September 10, 2015 If you edit your workspace, there is a menu command called Custom Visibility in the Legacy folder. You can use this to automatically write scripts to show and hide objects based on whatever criteria you want. It was removed from the standard workspaces a few versions ago. And remember if you are using scripts to change visibility settings, the most important script of all is just a single line: SHOW(ALL); This will set the object visibility of all objects to visible. Usually does not do much good to hide objects if you can't get them back. Quote Link to comment
Ozzie Posted September 12, 2015 Share Posted September 12, 2015 Pat = Genius sometimes mostly Quote Link to comment
