Vectorworks 2015 , 64bit and other technical questions
  • Replies 326
  • Created
  • Last Reply
Top Posters In This Topic
Fantastic news. If it all works then this is a really great addition. We re-map all of the colors as textures before export and this can be very time consuming.
This with the new modelling tools are very good news for us and a step in the right direction for interior designers
Well done
To give a general idea of the level of fidelity that is possible with the SKP and 3DS import now, here is a screenshot of an SKP imported into Vectorworks directly without any changes:
[img:center]http://i.imgur.com/z4G0pmq.png[/img]
This is a combination of the mesh smoothing feature and texture import.
Edited by JimW
3D hatches, are they image based or vector based?
The level feature, are they "live" and do the levels appear in all 3D views? i.e. plan view, elevations etc
The hatches are their own component of the texture and use the hatch resource directly. They are not part of the image-based texture. However they do not create lines on the object that can be moved or snapped, they are part of its texture. (If thats not what you meant let me know and I'll take another whack at answering it.)
The levels are more of a organizational feature, you would not see them ever anywhere in 3D. That brief preview in the video is a bit misleading into how they work, it is showing what they do, not how they do it. The feature is fully explained and demonstrated in the New Feature Videos that will be released at launch.
With this new level scheme, will a slab be able to be bound to walls on different layers?
I'm going to go with a tentative yes, as you can now bound slabs to levels, which exist independently of Design Layers and Stories, which Walls can be bound to as well regardless of the layer they reside on.
However, if any of the industry specialists disagree, they would know more than I and you should take their word over mine. My grasp of the entire Story system, even as it was in previous versions is not as complete as I would like.
Well done
