667 -
Reputation
265 SpectacularPersonal Information
Location
Holland
Recent Profile Visitors
How to add IFC data panel in the Object Info Pallette data panel
Bas Vellekoop replied to Bas Vellekoop's question in Troubleshooting
Thanks! Apparently you can hide it not only in the hamburger menu but also by moving the line under data sheet. π It was hidden and by moving the line i found it π -
Bas Vellekoop posted a question in Troubleshooting
Hi all, Probably a simple question, but I canβt seem to find the answer. How can I make the IFC Data panel appear in the Object Info Palette when using my own custom workspace? Any help is appreciated π -
Placing all symbols from the recourse browser on a Design Layer
Bas Vellekoop replied to Bas Vellekoop's topic in Marionette
Whoopwhoop π Indeed going to test this soon. -
@Pat Stanford Thanks for all the search results! @Marissa Farrell This node / marionette script is was looking for. Is there a way of getting it back? -
Redschift - round edge shader
Bas Vellekoop replied to Bas Vellekoop's question in Wishlist - Feature and Content Requests
@BartH @JuanP @Hans-Olav @zoomer @Tom W. @drelARCH @Kesoon Chance If you did not do it already: could you please vote this thread up with this button? Thanks! -
Bas Vellekoop posted a question in Wishlist - Feature and Content Requests
Hi all, To get realistic renderings for interior shots en smaller scale objects it would be very helpfull if the Roundedge shader would be added to Redshift - Vectorworks. By using this shader there is no need to model these round edges, but it is really helpfull to create highlights on models like kitchens, furniture and interiors to give them a more realistic look. https://help.maxon.net/r3d/maya/en-us/Content/html/Round+Corners.html -
Anyone tried working with Intel ARC integrated graphics?
Bas Vellekoop replied to jmcewen's topic in Hardware
I can recommend the zephyrus g14 of asus, take the top model in the serie. https://rog.asus.com/laptops/rog-zephyrus/rog-zephyrus-g14-2024/ Dedicated nvidia chip up to 4060 if im correct Great screen Greats size Great processor if you do some rendering Looks are nice as well Take the one with minimum of 32 gb ram and best grahpics card and processor I have 2022/2023 model. Its lightweight and small enough for my daily travels from and to the studio by bike. It is my workhorse and have no separate desktop. Biggest complaint is battery time, it is like 2 hours. If thats is a problem then go for a Apple macbook, because all intel and amd based laptops with some punch have this problem. -
Nope, there is not. (For these kind of things I switched to Fusion360)
Unwanted face overrides in VW 2022
Bas Vellekoop replied to Kaare Baekgaard's question in Troubleshooting
Any change that this still gets implemented on grouplevel? Would be very handy indeed π -
Christiaan started following Bas Vellekoop
Tobias Kern started following Bas Vellekoop
VW 2023 - profile line is gone in section viewports
Bas Vellekoop replied to Pavol D.'s question in Troubleshooting
Here you go π https://app-help.vectorworks.net/2023/eng/VW2023_Guide/LandingPage/New_features.htm?rhsearch=whats new&rhhlterm=what new Loving all te new features!- 7 replies
- 2
- 2023
- profile line
(and 1 more)
Tagged with:
Since version 2021 or 2022: if you make a symbol of the 'hole - tapped' object then you can change al the made subtractions by editing the symbol. Ideal because you cant forget one. (Instead of going into the different solid substractions and having to edit them one by one)
Associative Dimensioning on 3d models
Bump π- 7 replies
- associative
- dimensions
(and 2 more)
Tagged with:
Calculate weight from volume and density
Bas Vellekoop replied to Bengt Nilsson's topic in General Discussion
The new material resource is probably the way to go in combination with worksheets. In the past for product design i used it quite allot as can be seen in the attached picture. Then i used symbols and classes to get the right objects in the worksheet. This example is a sofa. But i used ut for the calculation of the weight of chandelier as well. It's good to know if the electric cord wil hold it π- 5 replies
- workflow
- total weight
(and 1 more)
Tagged with:
Using symbols for furniture design components.
Bas Vellekoop replied to Bruce Kieffer's topic in General Discussion
For screws etc it is great. For other parts of the design in my experience as well. With the option 'show other objects while in edit mode' editing is as easy as it would be just an object in the drawing. Its just right mouse click > edit 3d component With the creation of symbols of all the different parts of an (sub) assembly it is fairly easy to create separate design layers where you put each individual symbol on. You can use these design layers for easy for editing (if needed), and they are ideal for setting up sheet layers of each individual part for annotating and dimensioning. The only thing I`m really missing is auto updating dimensions as in Fusion 360 or other more product design focused programs. auto updating dimensions would save allot of time and possible faults. Automatically filling record or worksheets with length height with is not possible, but records for the creation of a Bill of Material can be very handy. This is a fairly simple one: In combination with Data tags and design layer viewports it is even more fun π And with some simple math you can get weight of your design and can change your design if that is needed based ont that. And if you just want to show and annotate parts and create flat patterns with the bending lines etc. π : So allot is possible with symbols π
