acepernich
Content Count
155 -
Community Reputation
1 NeutralAbout acepernich
Rank
Journeyman
Personal Information
Occupation
Architect
Location
San Francisco, CA, USA
To keep the hatch rotate with the rectangle, you could set the hatch to rotate in symbols. Then apply the hatch to the rectangle, and turn the hatched rectangle into a symbol. Kludgy, but a way to do it.
Are these youtube videos supposed to have sound, because I'm not hearing them?
Generating part size cultist for wood shop
acepernich replied to Chris Brough's topic in General Discussion
I'm not sure what you mean. If the volume of a 3/4" x 2" x 30" part has a miter on the end, the volume is less than THxWxL. So =volume/(height*width) will not return the correct depth (or needed dimension). That shouldn't bother a part size CULTIST. (never mind) -
That shouldn't bother a part size cultist. -
Correct. You can modify a pattern or create a new one, but not arbitrarily rotate one.
Patterns are arrangements of actual dots, therefore can't be arbitrarily rotated. Hatches, however, can. In the Hatch creation/editing window there are check boxes for Rotate In Wall and In Symbol. Checking the In Wall box will align the hatch with the wall direction. (Reply edited)
Uh... 1. In the hatch example given, square ends would look just as bad (ragged) as the round ends. 2. For the OP, for the occasional thick lines desired with square ends, you can use the double line tool to make polygons, 0 thickness line wt., and fill them. Also lets you edit the outlines (say, when the lines don't meet at a right angled corner - square ends would look worse than round ends). Having the outside boundries of lines at corner meet at a point is something I thought Postscript could do.
Half of one, six dozen of another ... Where the font name is displayed using the font, is annoying where you have lots of symbol fonts. Something hybrid might be good - the name in the selected font and also in a generic text font.
The obvious question - when you select line type 2, is there any geometry selected? If so, you are only changing the line type for the selection - the default stays the same.
Try using another keyboard - it appears that the shift key and some of the punctuation keys aren't working.
Vectorworks 2015 , 64bit and other technical questions
acepernich replied to PVA - Jim's topic in General Discussion
Did the timing of Apples announcements have anything to do with the timing of your newfound freedom to discus VW2015? -
Is a 'dutch teaser' anything like a 'french tickler'?
And just who is your badger supplier?
How to show "?" properly in dimension?
acepernich replied to stevenkhsiu's topic in General Discussion
Check that the font you are using even has that character (off chance). Also, from your systems character palette, copy & paste into the leader field. -
Zoom level for print size screen view
acepernich replied to Christian Fekete's topic in Architecture
Actually, it would be nicer for the program to read the display info (resolution, etc,) from the system, and do the scaling internally to display at true 100%. NVW? hint, hint?
