Atchison Posted November 1, 2010 Share Posted November 1, 2010 (edited) I have set up a page with various text sizes for reference, but all text seems to be printing at a smaller size than that specified, e.g. 7.0mm text prints at approx. 5.0mm, 5.0mmm text prints at approx. 3.5mm, 3.5mm text prints at approx. 2.5mm. The 'reduction' factor seems to be 1.414 i.e. square root of 2. Anyone have any clues? Page has been set up at 1:100 Edited November 1, 2010 by Atchison Quote Link to comment
propstuff Posted November 1, 2010 Share Posted November 1, 2010 root 2 is the factor between A and B series adjacent paper sizes. Are the print etc settings OK. Also; are you printing from a Sheet or Design layer? Quote Link to comment
Atchison Posted November 1, 2010 Author Share Posted November 1, 2010 Have set up the text on a Design Layer (Scale 1:100), and then created a viewport on a Sheet Layer (Scale 1:100), with the result as noted above. Quote Link to comment
bcd Posted November 1, 2010 Share Posted November 1, 2010 What size sheet is you Sheet Layer - Is your printed sheet the same? Is it only text that is re-scaling for you - or will a square print out the correct size? Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted November 1, 2010 Vectorworks, Inc Employee Share Posted November 1, 2010 It sounds like your Page Setup is wrong. Have you chosen the paper size using the Printer Setup button? Also ensure your printer is not scaling during the spooling process. Quote Link to comment
Atchison Posted November 1, 2010 Author Share Posted November 1, 2010 The page setup and sheet size are the same for both Design and Sheet layers. It is only the text that is the wrong size - shapes print out correctly. Quote Link to comment
Pat Stanford Posted November 2, 2010 Share Posted November 2, 2010 Check the Advanced Properties button at the bottom of the OIP for the viewport and make sure the Text Scale is set to 1. Quote Link to comment
propstuff Posted November 2, 2010 Share Posted November 2, 2010 Go to the Advanced properties tab in the OIP for the Viewport on the sheet. What does the Text Scaling value say? Quote Link to comment
Atchison Posted November 2, 2010 Author Share Posted November 2, 2010 Text Scaling value is set to 1. Quote Link to comment
Benson Shaw Posted November 2, 2010 Share Posted November 2, 2010 Is this a typography issue? eg In my VW, an 8mm Helvetica "T" has 5.74mm height. The remainder of the 8mm is for decenders, ascenders, and, probably some never occupied border. -B Quote Link to comment
Atchison Posted November 2, 2010 Author Share Posted November 2, 2010 I think you're right. When I type in text like [Type] the overall heights of the text are close to the mm sizes specified in the OIP. Thanks. Quote Link to comment
Benson Shaw Posted November 2, 2010 Share Posted November 2, 2010 The height of a VW text character can be measured by converting it with the TrueType to Polyline command. The new bounding box will be limited by the extents of the new poly. It's no longer editable font, but it can be resized as needed with OIP or rescale command. A font character will have bounding box dimensions determined by the font parameters and conventions - generally larger than the character extents. There may be some fonts or software which display character height equal to font height. Is that what you mean by "TYPE" ? I don't have a font by that name. Anyway, I hope you find a font and size that works! -B Quote Link to comment
Jershaun Posted November 2, 2010 Share Posted November 2, 2010 I've put this on the wish list a couple of years ago. The text doesn't relate to an input size. If I make a text 5mm, and measure the text, I have no clue what vw has used for the 5mm. The text definately isn't 5mm. Also the text changes as per different fonts. This makes text in vw extremely innaccurate. If you place a 5mm text in AutoCAD, you can actually see where the 5mm is used to give the text size. This must be fixed in future versions of vw. Quote Link to comment
