Actually, I found it.
Surprise.
It took quite a while to translate to 2024 but got there in the end. Update to the Parasolids 3D engine??
pillow v2024.vwx
Sorry, that was 16 years ago. The file is lost to time....
The Forum also seems to have lost the image files that were attached.
I have barely touched SubDiv, so I'm not sure, but that may well be an effective way to go these days.
N.
Sorry, but are you rendering the scene on screen (or something like that) and then exporting the screen via iPhoto?
If you're unfamiliar, the best thing is to use the VW Export Image File command. Then you have "complete" control over it. You also dont have to wait for it to render to export.
Start it off in the render mode you want then hit Esc to stop the render. Then go to the export dialogue.
HTH
You shouldn't need to go that large. I rarely export at much more than 2000 across because that comes out at a file which will print to A3 happily and any more is a waste of time etc.
Try exporting at 800 or 1000 (but not double, because -like harmonics- you might get the interference pattern again).
Moire patterns are from small mis-matches in pixel/dot spacings as Mike said.
Have you tried changing the output resolution of your renders a bit? This *should* make the small mis-match a large mis-match and the patterns should go away.
HTH
Well I just tried it: (intersecting lines turned on)
with a VW2012 file; interior of a house: 13 seconds
The same file opened in '13 took less than 4 seconds
So I'd be calling that 3 times faster -on a mac. So presumably on widows it would be faster again.........
The menu item is missing out of my Designer workspace but it can be added in the workspace editor
Looks like a little oversight in the release
I bug listed it
