Hi Jonathon, I have a Design Layer Viewport which appears as below. When I double click on the Viewport I'd like to be taken to that part of the Plan immediately.
Instead
When I double click on a viewport, e.g. a viewport showing a plan, how can I have the view of the plan be located at the same place as the view of the plan in the viewport?
Simple question. How can Viewports be renamed after they are created? I've gone to Organisation Palette, Viewports, Edit, but there is nowhere to rename the Viewport.
Problem was solved by Julian at Ozcad.
'Try going to the Tools Menu/Origin command and choose Set User Origin to Internal Origin option, to see if that makes a difference'.
The user origin of my drawing was set a long way from the internal origin.
I have one file where the object info. palette doesn't show data for objects and won't allow me to input data. All other files are working ok. Is there a setting I've missed?
I often have the background render mode for Viewports set to Sketch (for the Schematic stage of projects). When I click on Edit Design Layer for the Viewport the Design Layer always displays in Sketch mode.
Is there any setting I can use to have the Design Layer automatically display in Wireframe?
Invisible classes contain several different object types - lines, polygons, symbols .
The problem is intermittent - this morning it's not picking up the invisible classes.????
When I create a polygon using Inner Boundary Mode the polygon is picking up classes which are turned off.
Is there a way to avoid this so the boundaries of the polygon are formed by only the visible classes?
Since upgrading to VW 2016 my saved wall styles are not displayed in the list of wall styles available.
I have checked that the file with my saved wall styles is in the correct Walls~Slabs folder in the User Folders.
Has there been a change made in 2016 re the display of user resources that I am missing?
