I've recently started using VW2024 for my active projects. There seems to be something wrong with symbol creation that doing my brain in. Try this -
- create a 3d object like an extrude located away from the origin.
- make it into a symbol using Plan Projection Centre as the Insertion Point.
- Now look at the symbol's position in the OIP. All the ones I create show the symbol at 0,0,0.
The symbol does not have the Plan Projection Centre of the 3d object as its Insertion Point. Instead it is using the origin point as its Insertion Point. See screen shots below.
I create symbols this way all the time and the first few times it happened I got very confused because symbols weren't inserting as expected. This has to be a bug.
Can someone else try this and confirm the behaviour I'm seeing?
Kevin McAllister
Hello,
Kevin
Test Symbol.vwx
12 answers to this question
