doug shaffer Posted October 6, 2023 Share Posted October 6, 2023 Hi, again - Yesterday I submitted a question (bug) regarding sills not being represented properly when using the Window tool (Vectorworks Architect 2024 - latest update). Today I discovered another problem the 'Custom' configuration within the Window Settings pane. Basically, when I choose a 'Custom' configuration with multiple 'columns', there is a 'mullion' missing between the first and second columns. AND it appears that this missing mullion shows at the opposite jamb side. Attached are two screen captures showing the issue. Also, where can I submit both of these windows issues as a Vectorworks Architect BUG? Thanks for any help you may be able to offer. Quote Link to comment
Tom W. Posted October 6, 2023 Share Posted October 6, 2023 I think @Matt Panzer has already submitted a bug regarding problems with the 2D graphics of custom windows so he might want to link your post to that bug rather than have you submit a new one... Let's see what he says! I still say I was experiencing some of these problems prior to VW2024... 1 Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted October 6, 2023 Vectorworks, Inc Employee Share Posted October 6, 2023 Yes. This is a known issue: 2 Quote Link to comment
E|FA Posted October 6, 2023 Share Posted October 6, 2023 (edited) For future reference, you can try https://www3.vectorworks.net/vectorworks-bug-report but don't expect to get a response or even confirmation the bug report was received. The forum still seems like the best way to do this. See: https://forum.vectorworks.net/index.php?/topic/97410-idea-for-tracking-viewing-tech-support-request-status/ https://forum.vectorworks.net/index.php?/topic/93660-service-select-support-add-a-ticketing-system/ Edited October 6, 2023 by E|FA 1 Quote Link to comment
doug shaffer Posted November 21, 2023 Author Share Posted November 21, 2023 Well, I downloaded VW 2024 Update 2 and there are still problems with windows with custom sash settings. ARGH. In a two sash custom window, strange things happen when making the left sash wider than the right sash. If the left sash is narrower than half the width of the overall window, everything is okay. The attached file shows the problem. I discovered this within five minutes of using VW with Update 2. Please let me know if you can recreate this problem. Very frustrating. Quote Link to comment
Administrator JuanP Posted November 22, 2023 Administrator Share Posted November 22, 2023 @doug shaffer Submitting your issue to our R+D team. I will report back with any updates. Thank you. Quote Link to comment
Administrator JuanP Posted November 22, 2023 Administrator Share Posted November 22, 2023 @doug shaffer Could you send us a small file with only the problem example - i.e., One Wall One Window? Sometimes, that helps us to find the issue faster. Thank you. Quote Link to comment
doug shaffer Posted November 23, 2023 Author Share Posted November 23, 2023 22 hours ago, JuanP said: @doug shaffer Could you send us a small file with only the problem example - i.e., One Wall One Window? Sometimes, that helps us to find the issue faster. Thank you. Thanks, Juan - I appreciate your prompt response. Attached is the test file I had made. It was started from scratch. Best - Doug window problems-VW2024-update 2.vwx Quote Link to comment
Kevin K Posted November 23, 2023 Share Posted November 23, 2023 @doug shaffer perhaps in the meantime until your issue is resolved...you could create a Windoor window and see if you get better results? I have no idea if you have installed Windoor ?? It is installed through the 'Help' Menu item "install partner products" There is a bit of a learning curve on using Windoor, but it shouldn't kill ya. Here are a couple screenshots. Let me know if you want the actual 2024 file. I kinda had to guess on the overall window size 🙂 2 Quote Link to comment
