doug shaffer
232 -
Reputation
6 NeutralPersonal Information
Occupation
architect
Homepage
www.msmkc.com
Location
kansas city, mo, usa
Recent Profile Visitors
Vectorworks Architect 2025 - Eye Dropper tool and Windows
doug shaffer replied to doug shaffer's topic in Architecture
Never mind... I figured it out. I tweaked the Eye Dropper preferences to make it work as expected. -
Hello - We create windows in VW using the standard window plug-in object. In the past I was able to use the Eye Dropper tool to copy the configuration of one window to another window. This doesn't seem to work in VW 2025. Can I no longer use the Eye Dropper tool to do this or am I missing something? Thanks - Doug
Representation of Window Sills in Masonry Walls - 2D
doug shaffer replied to doug shaffer's question in Troubleshooting
It appears that VW Update 2 did not address this window issue. Is that correct? Thanks - Doug -
Well, I downloaded VW 2024 Update 2 and there are still problems with windows with custom sash settings. ARGH. In a two sash custom window, strange things happen when making the left sash wider than the right sash. If the left sash is narrower than half the width of the overall window, everything is okay. The attached file shows the problem. I discovered this within five minutes of using VW with Update 2. Please let me know if you can recreate this problem. Very frustrating.
That all makes sense, Matt. Thanks for your help! -
Hi, Matt P. - To clarify, are you saying that the VW 2024 Update 1 should fix the issue that I originally posted about? (see first message in this topic) If so, nothing has changed for me since I installed Update 1. And if I rotate the wall containing the window the sills get totally screwed up and I have to move it 0" to get it to reset as you described earlier. I also noticed that if you copy the window, paste it in place outside of the wall then drag to insert back in to the wall (or a different wall), the offset is changed to 0". Update 1 did nothing to change window problems as far as I can tell. See attached screen capture. This and the complex window mullion issue are critical issues that need to be addressed asap. Any timeline for a solution? Thanks - Doug -
I can't seem to find anyone else on the forum that's dealing with this issue. Like it says in the subject line, every time I quit VWA 2023 or 2024 I get an error message saying "Vectorworks 202X quit unexpectedly." I have not noticed that there's any file damage when re-opening the files but it concerns me. Is this a bug in VW or Sonoma? I have all the latest updates for VW and Sonoma and I'm using a 2019 MacBook Pro. I can copy / paste the "Problem Details and System Configuration" if that would be helpful. Thanks for any help you can offer - Doug
Hi, Juan - I just sent the file. Let me know if you need anything else. I appreciate you and your team addressing this. Best - Doug
