Often I'll be looking at a section viewport, on a sheet layer, and realise I need to change the position of the section line that generates it.
Doing this is tedious - unless I'm missing some quicker way of doing it.
Many of my section viewports don't have an associated section line on an "active" viewport within the drawing set.
My process is:
- select the viewport
- go to the OIP
-scroll to the bottom
- press "section line instances"
- select "viewports"
- find what I call my "section control viewport" in the list
- put a tick next to it
- press "activate"
- zoom out and find the section line, in the annotation space of this big mess of a viewport which is where I keep an instance of any section line I've used/want to adjust
- move that line to where I want it, wit some difficulty, because that viewport might not clearly show the objects I want to position the section cut relative to
- exit the annotations
- try and remember which sheet the section viewport was on, find it in the list and go back there.
What I'd like:
- right-click on the viewport
- get an option "relocate section line" and select it
- be taken to an orthogonal view of the model, showing only layers & classes contained within the viewport I've come from, with the section line clearly highlighted and ready to be moved
line-weight
My process is:
- go to the OIP
- press "activate"
What I'd like:
- move it
- click "return to viewport".
Edited by line-weightLink to comment
31 answers to this question
