joerg Posted October 12, 2022 Share Posted October 12, 2022 how could i apply a text arround an extruded oval as a texture so i appears only onceon the outside?. ( i am aware of extruding a text along a path) Quote Link to comment
Jeff Prince Posted October 12, 2022 Share Posted October 12, 2022 Use a decal. 3 Quote Link to comment
Kevin Allen Posted October 12, 2022 Share Posted October 12, 2022 or per face... 3 Quote Link to comment
joerg Posted October 14, 2022 Author Share Posted October 14, 2022 @jeff princeI tried decal but my preverred rendermode "shaded" doesn't render decals!!! @Kevin Allen with per face i am not able to select multible faces and to convertmesses up the whole object. It seems easy but isn't Quote Link to comment
rDesign Posted October 14, 2022 Share Posted October 14, 2022 Maybe you could convert the extruded oval to NURBS, and then apply the ‘text’ texture to only the outer facing NURBS surface. Quote Link to comment
joerg Posted October 19, 2022 Author Share Posted October 19, 2022 i tried nurbs but it will convert to three nurbs... this should be easier;( Quote Link to comment
Kevin K Posted October 19, 2022 Share Posted October 19, 2022 Joe Here is one method, I believe, where you can have some control of where some text will be placed as a texture on an object, JUST ONCE 🙂 You may need to mess with the Render settings a bit to move the text around on the exterior Nurbs surface. Some things to consider: 1) convert your extruded oval to nurbs surfaces...you should end up with 4...outside, inside top & bottom. 2) Do make sure you have your Shaded options set to very high. 3) When you create a texture from whatever text you wish to use, make sure that you use 'single', not 'infinite' and uncheck both repeat Horizontally and Vertically....this way you end up with just one instance of the texture. 4) Select the outermost Nurbs surface, which should be one continuous surface, then apply your texture. At this point you can move the text all over the place, on that shape, by using the controls within the Render Tab. DO make sure to use 'surface' option map type, and not any of the others. 🙂 See if this works for ya.It may seems like a lot of work, but really it is pretty quick and simple. I attached my 2022 file, so mess around with the settings, etc. -Kev TEXT WRAP 2022.vwx 1 Quote Link to comment
mjm Posted October 19, 2022 Share Posted October 19, 2022 7 minutes ago, Kevin K said: Joe Here is one method, I believe, where you can have some control of where some text will be placed as a texture on an object, JUST ONCE 🙂 You may need to mess with the Render settings a bit to move the text around on the exterior Nurbs surface. Some things to consider: 1) convert your extruded oval to nurbs surfaces...you should end up with 4...outside, inside top & bottom. 2) Do make sure you have your Shaded options set to very high. 3) When you create a texture from whatever text you wish to use, make sure that you use 'single', not 'infinite' and uncheck both repeat Horizontally and Vertically....this way you end up with just one instance of the texture. 4) Select the outermost Nurbs surface, which should be one continuous surface, then apply your texture. At this point you can move the text all over the place, on that shape, by using the controls within the Render Tab. DO make sure to use 'surface' option map type, and not any of the others. 🙂 See if this works for ya.It may seems like a lot of work, but really it is pretty quick and simple. I attached my 2022 file, so mess around with the settings, etc. -Kev TEXT WRAP 2022.vwx 203.55 kB · 0 downloads Very clear & succinct, thanks @Kevin K Quote Link to comment
Tom W. Posted October 19, 2022 Share Posted October 19, 2022 That method doesn't work with @joerg's shape unfortunately: Quote Link to comment
Kevin K Posted October 19, 2022 Share Posted October 19, 2022 One more thought about this…because, in the file I posted, the outside nurbs surface is continuous, and not broken up into several nurbs, you can place the text anywhere on the surface. Sorry, I forgot to mention that. Quote Link to comment
joerg Posted October 21, 2022 Author Share Posted October 21, 2022 Thank you very much i will check that out...! Quote Link to comment
joerg Posted October 21, 2022 Author Share Posted October 21, 2022 hmm how would i combine three Nurbs into one...? Quote Link to comment
Kevin K Posted October 21, 2022 Share Posted October 21, 2022 Joe Another thought related to what you wish to do with adding text to a 3d object, and in this scenario, I think you may be better off rather than than messing with trying to use the text as a texture, seems to me. Just type your text, in this case, in an elevational view, NOT top plan, and convert the text to polylines from the text menu item. Then you have the advantage of extruding the text lettering a bit, moving text where you want it, and even color or texture each letter of the text, if you wish. Point being, you have a few more options using the methodology. You can simply place and/or nudge the text a micron in front of the surface of your 3d object. If you need to apply the text to a curved surface, you can deform each letter a bit, although this is a bit more advanced 🙂 I did do this to a few letters of text so you can sort of see in a top plan view how that works. I just gave a few of the letters a little 'Bend' with the deformer tool. IF you can just keep things simple and apply the text in front of a flat surface things will go really quick! I attached an updated 2022 file as a reference. Hope this helps. -Kev TEXT WRAP 2-2022.vwx 3 Quote Link to comment
Kevin K Posted October 22, 2022 Share Posted October 22, 2022 Joe You really opened up Pandora's box here 🙂 Not really sure the purpose of your extruded oval, but one last thought if you do choose to convert the text to polylines, then extrude them...you can 'subtract solids' so the text lettering is set back a bit and subtracted from the extruded oval. Gives the inset text a a little dimensionality. 1 Quote Link to comment
Tom W. Posted October 22, 2022 Share Posted October 22, 2022 (edited) 17 hours ago, Kevin K said: If you need to apply the text to a curved surface, you can deform each letter a bit, although this is a bit more advanced 🙂 I did do this to a few letters of text so you can sort of see in a top plan view how that works. I just gave a few of the letters a little 'Bend' with the deformer tool. IF you can just keep things simple and apply the text in front of a flat surface things will go really quick! I think you've cracked it @Kevin K. To make it easier you can use Add Solids to make a single Solid Addition from the individual letters which you can then Deform as a single object Edited October 22, 2022 by Tom W. 2 Quote Link to comment
