I'm looking for a way to globally set values of multiple lighting devices' Voltage, Time, Cost, and Weight parameters.
I know I can do this after I insert the Lighting Devices but I'd like to have their values already set before insertion.
I know that I could change the Weight in Lighting Symbol Maintenance but the other parameters (Voltage, Time Cost) don't appear in this window.
I was able to add these fields (Voltage, Time, Cost) to the Light Info Record allowing me to set these field values before insertion.
Even after I added these fields to the Light Info Record, they don't show up in the Lighting Symbol Maintenance window. Why is this? Can they be added to this window?
I want to be able to bulk edit the Voltage / Time / Cost of multiple lights at once. Is there a solution for this?
Thank you,
Zack
Vectorworks Spotlight 2023 SP7 (Build 719048) (64-Bit)
MacOS Sonoma 14.1 (23B74)
