LMorga
28 -
Reputation
4 NeutralPersonal Information
Occupation
Area Manager - Rigging Services - Encore Global
Location
United States
Recent Profile Visitors
I have seen this before I don’t remember exactly when. But I think it is a symbol level issue.
This is definitely a bug, or possible bug. I have found this in a few files in our workflows. To verify when you see the trim height issue, go into a front view and cross check your rulers. Z-zero will not be 0. There is no way to adjust the internal or user z origin. Work around fix is to copy and paste in place file data to a new uncorrupted file. We have found this to happen between DWG conversions.
Hey Pat, discussing this with Steve, there is a bit of misunderstanding. The script Steve is looking to make work would be, to initiate the truss tool. Then have the tool set to navigate to a specific VW truss symbol resource, to prepare for symbol insertion.
VW 2025 Bug or Not Operating as Expected - Thread
LMorga replied to LMorga's question in Troubleshooting
Following up this discussion, my request for support was responded to today by email requesting me to upload screenshots or screen recordings to a VW Portal. https://vectorworks.groupdropbox.com/upload/ed0ea000fbdd6df43ca5680c89cfa9b0 -
Finally, received an email from support team to upload in a VW Portal. https://vectorworks.groupdropbox.com/upload/ed0ea000fbdd6df43ca5680c89cfa9b0
So, the thought was remove the shortcut for a tool of a longtime useful legacy tool and added it to a feature of the parent tool. Brilliant decision, I would hope the thought of utilizing unmapped keys for your tools, would have been part of the conversation. Also, the lead time for support currently at 72 hours patiently waiting.....
I have a solution for this we can discuss Nick.
Following this discussion up. I have submitted a request for support through the portal and left multiple voicemail with a requests to follow up. Patiently waiting..... -
Thank you, for the reply and your thoughts. But the point still exists. I'm well aware of workspaces and the customization options therewithin, respectfully. Again, some things are best left undisturbed...
FYI default Visibility short cut is no longer available. It has been rerouted in default to display toggle of Ghosted items. IMO this was frustrating and I reverted the visibility tool back to previous deployed defaults. The new ghost toggle could have been coded to an available open key that was not already in use.. Not sure why that was a decision that was decided to be the best choice.
What is the best way to document? Screen recordings? -
I have noticed a few things: 1. Copying resources from file2file in resource browser causes some sort of program issue. 2. Data Visualizations will not activate from top level interface. Must currently access edit interface of DV items to activate. 3. In purge confirmation interface, unable to shift select, group selection. Must select individually. I hope this format is useful and helpful.
Hi I`m looking for the official 2025 SDK. On the normal download page it only lists the 2024 version. Thank you!
@Wood I developed a Tyler 12x12 AV 3/16 file. I will send you to test. I want to get the SGPS files you shared, setup.
@Wood Use the PA truss calculator. We then make a custom user CS in VW. Cross Section name will be :USER [Field Value]
