284 -
Everything posted by Mat Caird
Hi Zoomer To display the fill; Double click the section viewport, choose Edit | Section in place. Orbit the view to suit. In VW2023 you can rotate/orbit the view (I don't think this was possible in earlier versions of the edit section in place feature.) Here's the test file showing the fill; Still no lines.
Hi All. Can anyone explain me how to remove these vertical lines on my site model please; I've set up a test file, and the test file does not display the lines for some reason. Thanks in advance all. Mat
Lights in shaded viewports behaving erratically
Mat Caird replied to Mat Caird's question in Troubleshooting
Hi Dave, yes they are. FWIW I use classes to control the visibility of lights rather than the vis. palette. Thanks, Mat -
Hi All I have 6 light objects used to illuminate the interior of my building. These lights are on their own class, and all the lights are set to 'on' in the OIP. They act as expected on the design layer as below; I have created a sheet layer viewport (below), and the lights sometimes work, and sometimes don't. I have tried deleting and redrawing the lights. I have tried switching them on and off in the OIP. I have checked classes and layers, and all seems correct. Any ideas anyone? TIA
How to modify slab (roof) drainage to outlet at perimeter scuppers?
Mat Caird replied to architele's topic in Architecture
I always use roof faces for this kind of thing. Basically, I just model the plywood.... You can use the extract surface tool to quickly model the rubber membrane. You'll need to move it slightly so it sits above the plywood. It will work OK in a cross section - I'd annotate the plywood in section with a plywood hatch I use. You'd need to manually annotate the slopes per sheet. -
Coordinating representation modes in plan and section...
Mat Caird replied to arquitextonica's topic in General Discussion
I use a "Tile" I've created in order to represent the floor covering. I draw a rectangle/polygon (on the layer plane), apply the Tile via the attributes pallet. I don't bother doing this for carpet. It seems to be quick and easy. Also, I can use the attributes mapping tool to quickly suggest a tile layout for the builder. Probably moving forward I should use the Floor tool, which would then show thickness in a 3d view. Draw the outline of the floor, set the fill attribute to the Tile, then AEC|Floor. Let me know if you want instruction on building the 'tile'. . -
vectorworks 2023 startup freezing on loading cineware
Mat Caird replied to sLMA's question in Troubleshooting
My setup is the same as Dave's and startup experience same as Dave's. -
There are a number of ways; You could draw a rectangle in this section orientation and extrude it - probably easiest method but mayn't show correctly in top/plan. You could draw a rectangle in top/plan view, the AEC|Floor - a bit more fiddly than method 1. You could delve into the render setting of the slab you've drawn, and change the "sides" texture to appear how you want. - this might look good in elevation but won't be noticeable in the section view. I've been using the framing member tool to draw fascias, and it works quite well. Making a new wall style to cap it is probably the most hassle. - I'd personally avoid that approach. Here attached an example using the framing member tool;
Text in Design Layers - Matches Scale in Sheet Layers
Mat Caird replied to Paul N's topic in General Discussion
If you label the contours on your design layer, then create a sheet layer viewport at a different scale, you can use the Advanced Properties to scale the text. It won't change the viewport annotation text size, only the text on the design layer visible in said viewport..- 1 reply
- 1
Thanks Jeff, but no. I really want to delete all the default stamps and replace them with my preferred phrases.
Hi All, does anyone know where I can edit the Stamp Text defaults list please? Currently I need to enter the custom text for each Titleblock, but presumably there's a text file somewhere populated with the other stamps? OsX. PFA. TIA. Mat.
I would normally draw the wall with one or more components which actually overhang and therefore conceal the slab. But here for you, the easiest way may be to double click the slab (in plan view), and in the Edit Slab dialog, choose Boundary, and then resize the boundary to be on the inside face of the wall. So I would have in mind the construction method before I start modelling;
Roof Object: cross gabled roof when verge is flush with main eaves
Mat Caird replied to Christiaan's topic in Architecture
Change multiple viewport rendering styles with 1 Click
Mat Caird replied to Mat Caird's topic in Vectorscript
Thanks Julian for answering. I can't do them all in one hit for a couple of reasons; 1. A section viewport and a 'normal viewport', if both are selected, and the background render mode is set to shaded, the background render settings are not available. 2. I have 11 hidden line viewports, 11 section viewports, 19 shaded VPs, 7 wireframes. For the full colour set, all except the wireframe can use the same settings so that is easy enough. But for the black and white set, the hidden line viewports I need to set differently from the shaded VP's, then there're 2 types of shaded viewport (section VP and normal VP). If there was a VS function to select the individual background render settings for each VP, then I'd be able to write a 1-click solution to my scenario. -
Hi All I have a house project file with 49 Sheets. There are 119 viewports in the project, some wireframe, some shaded, some hidden line, some section viewports. I wish to export the project to PDF for the building consent/permit as black and white, with a subset of the 49 sheets. I wish to export a full set for the builder, in colour. I have modelled the entire project, down to nuts and bolts, in 3d, and I'm using the viewports to produce detail drawings at 1 to 5, elevations at 1 to 50 etc. I have placed the viewports onto classes describing their Background Rendering setting. eg "Viewports-building consent hidden line" I have used the Tools|Custom Modification tool to create a script to select viewports of the same Background Render. Then I manually adjust the render settings. EditProperties(((T=VIEWPORT) & (C='Viewports-building consent wireframe'))); I've looked at the Vectorscript Function Reference but cannot find any function to "deselect 'use textures shaded render'". Is it possible to edit the background render settings using VS? Thanks in advance. Apologies for the I have I have I wish I wish....... Mat
Vectorworks and Vision 2022 Service Pack 4 Available for Download
Mat Caird commented on JuanP's article in Tech Bulletins
- Resolves memory errors that occurred during viewport rendering Not fixed for me 😞 -
Redline Tool Data Tag Text Overlapping
Mat Caird replied to JimDenaultASC's topic in General Discussion
Hi Jim Try this; edit the class named Note-Redlines to <use at creation> in that class, tick use at creation in the Text Style box of the same class dialog then select your text style "Callouts 10 Pt" click OK - it might work, if not; find the attributes pallet, and left click on the 3 lines, beside the ? - choose "make all attributes by class" -it might work, if not; right click on the redline and choose "locate text style in resource manager", then right click on the text style, make sure the alignment is not set to top baseline, or bottom baseline. Change the colour of the text just so you can see if the redline is actually updating. Click OK. You'll probably need to "make all attributes by class" again. Finally, you might need to flip horizontally, or flip vertically your redline object. Good luck - it worked for me. -
lining up 2nd floor walls with 1st floor walls
Mat Caird replied to brent m kjernisted's topic in Architecture
Here’s an idea; make a new layer, call it "curtain wall". Draw the curtain wall on this layer Make another new layer, called "floor plan 1" draw the program same for another new layer, floor plan 2. Etc Make sure all 3 layers are the same scale. use the layer options "show snap modify others" turn on/off layers 2 and 3 as necessary an alternative; if the curtain wall is aligned perfectly (as it would be IRL) across both floors, and drawn on both floors (layers), VW will display it as one wall in elevation, 3d, section views. Provided the wall style is the same on both layers. Mat -
Indication of the symbol, materials, dimensions and in general records
Mat Caird replied to ShelterS's topic in Architecture
Is this what you mean; If so, then use the callout tool, with "Get Text From Database" You'll need to build your database manually. The first time you place the callout, the Keynote Legend will get automatically inserted onto your drawing - might be off the screen somewhere so you'll need to look around for it. -
Escalating RAM usage on small files making Vectorworks 2022 Unusable
Mat Caird replied to Jack2022's question in Troubleshooting
I had a similar problem on my M1 MBP 32GB. VW would work fine until I updated a particular viewport. Then all aspects of VW would become unusable until I restarted VW. I found the problem to be some "climbing holds" I'd downloaded. They were 3d meshes, converted from sketchup I believe. Funnily enough, in the model layers where they resided, everything worked normal. It was only after updating the viewport (section viewport, shaded rendering) where the bug occurred. I solved this by deleting the climbing holds 😞 I didn't bother submitting a bug report. -
Detail callout tool issue
Mat Caird replied to hollister design Studio's question in Troubleshooting
I found that in an existing file, when I drew the detail callout, it created on a 3d plan. If I changed to Layer plane, I was then able to "create detail callout". When I created the detail callout in a new black file, I t created on a layer plane, and worked as expected. Mat
