Siradrad
    13
Reputation
2 Neutral
Personal Information
  • Occupation
    Real Estate Developer
  • Hobbies
    Skiing, Kiting, Biking, Design
  • Location
    United States
Recent Profile Visitors
559 profile views
  1. Thanks Tom, you are correct that was precisely what was going on. Thanks for the heads-up on sig, also.
  2. I cannot delete a space tag, I get this error I can not seem to get to the space style settings dialog. Does anyone have a good resource for creating custom space tags I am perplexed by the workflow and behavior.
  3. I am having this awful problem where the contour text multiplies on top of itself. Deleting it is nearly impossible as it updates the site model with each delete, and in some cases there are many. Does anyone have a work around? File attached. Siteplan_W_Contours-Modifiers_3D_v2023.vwx
  4. Thanks Jeff, I was thinking this might be the way to go.
  5. Anyone have any ideas how one might edit a CMU wall to have geometric openings like breeze block?
  6. I am trying to detail the ends of a c4 for a landing. I notice that I am able to set mitre angles on the ends of the steel to various degrees, however, it sets the new dimension of the steel shape to the center of the mitre which is difficult because it is time consuming to compute the new size of the shape, is there a way to make the new dimension the end of the mitre instead of trying to find the center of the cord length across the mitre?
  7. I think you are right, I went to my structural shapes file in my libraries and the classes are all set to none. I suppose this is ok, But does it effect the record format, when I try to produce a worksheet that lists an appropriate column ftg and steel shape data? I guess my larger question is does some one have a best practices work flow for producing a Structural plan and then linking all the information to a worksheet? Including FTG's, colums, girders and lintels? It seems as if the only way to get FTG's to show up with the column tool is to pick Arch and Struct. drop down option and then deal with the shaft line that is placed around the structural shape. Otherwise the base (which is representing the FTG is not avail), unless I am missing something, which is prob. the case?
  8. What exactly does this error mean? I am trying to layout a structural steel plan and set FTG sizes in the column properties menu, but when I set it to structural only and try to enter steel shape and base sizes, I get a message saying "unknown container type cannot set classes?
  9. yuck very messy I sure hope this gets cleaned up. Good luck Tad, Don't want to show those renderings to your clients!
  10. Was working in a file when it VW kept needing to close, of course the mumbo jumbo in the error report means little. So I opened the most recent backup of the file hoping the file would no longer be corupted. It now runs fine but the window has lost some of its edit capabilities in the Object info palette namely the ability to change its layer is this yet another "bug".
  11. Hmm that is a bummer seems like there are a lot of bugs kind of annoying. Is 08 sp3 less buggy.
  12. I am using 09, It seems like some of the options disappear randomly when inserting a window from the resource browser, after multiple moves the window seems to loose its flip and set position option in the object info palette. What causes these options to disappear so I know what I am doing wrong. Also in my elevated hidden line render mode it seems like there are some ghost lines left over from the perimeter of the plug in object, that extend beyond the trim of the window. When I re-render they change a little but I can never quite get them to be gone? Attached is a picture of the blasted lines.
