987 -
Everything posted by Matt Overton
Fade other Objects in Edit Modes
Matt Overton replied to bcd's question in Wishlist - Feature and Content Requests
I agree Grey can be to confussing on complex drawings. Just not sure what you mean by fade. What would do differently to improve legablity? -
Traditional window schedules
Matt Overton replied to Christiaan's question in Wishlist - Feature and Content Requests
Could this work similar to the new internal elevation tool? Instead of wall elevations, it would produce a line of tightly cropped window elevations.- 24 replies
- window tool
- scheduling
(and 2 more)
Tagged with:
Vectorworks Steals Focus at inapproperate times
Matt Overton replied to Matt Overton's question in Wishlist - Feature and Content Requests
6:00 pm friday I'd like to go home. Trying to upload completed For Construction set to the builder/client/team. Vectorworks keeps stealing focus as it produces the DWG set for all concerned so I can't load pdfs in the webinterface as finder and web browser don't stay on the screen at same time. All I can say is ..... AAAAAAAAAAAAAARARRRARRARARARARARARARAGAAGGGGHHHHHHHHHHHHHHH............ -
Capitalisation control for Scale Bar Tool
It shouldn't even need a caps control. m equals meters M is meaningless in context. -
I'm sure there are others but the one I hit the most is... -Publish menu exporting. Vectorworks if pushed the background to run a publish set will bounce the dock icon and keep pulling itself up to the front application. So I then have to wait for the command to finish before you know writing the email to attach the published drawings too. - VAA Revise Issue Print is slightly better although does take out significant amounts of screen space with a window that stays foreground even if the app isn't.
Adding automatic breaks to viewports
Matt Overton replied to RussU's question in Wishlist - Feature and Content Requests
We do large scal wall sections that we then crop down it fit on page. It would be far better to have one section with breaklines handled by the viewport to compress the parts not needed. It it would also be useful to go the other way. Breaklines in viewports to allow them to span sheets.- 1 reply
- 1
Yes, there should. Even better if walls generally understood linings verse solid or structural elements. So that a brick wall would just show the brick stopping but a rendered brick wall would know to turn the lining around the end cap.
What is the best way to show a reflected ceiling plan?
Matt Overton replied to TArchit's topic in Architecture
You can fake flip the model by adjusting Layer stacking in the viewport. This only helps if you break each of your stories in to floor, walls(+spaces) and ceiling at a minimum . As it allows you change stackings and show the slab/structure above below the ceiling. Personnaly we show door swings on RCP's to avoid services clashes and electricians putting the light switch on the wrong side of the door. -
I'd say maybe 10% of the roof faces in my models are slopy slabs. Sometimes more like 50%. It would almost be fair say I use more roofs as slabs than slabs as slabs.
Referenced Files and Resource Manager
Favourites are good for shared resources in an office, but to me, I think the OP might be thinking more about projects specific symbols. Managing a favourites list around that is kind of clunky. Could we even go one further and sort reference vs home symbols into groups based on source? -
to renew or not to renew (that is the question)
Matt Overton replied to Phil hunt's topic in General Discussion
I think the problem is the curtain wall system shows that the plug-in system just isn't capable of handling complex geometry rich objects without vast improvements. A lot of the newer objects have the same problem. They are just to complex to turf all the calculations and start again. -
Especially if it tied in to the cloud services and ran on a touchscreen tablet or computer. Indeed 'VW-lite" almost as a skunkworks project to put as much function as possible each year on modern lightweight Touchscreen hardware. Could be a great way to target both markets where the value isn't there to warrant a full version. Plus have existing customers willing to kick the can a little more to help as better leverage the information we have already generated. I know I'd be interested if I never had to carry a mark up set again. The revenue stream then funds a new core engine that could well be ready when the great (ie. disruptive) transition occurs.
Line Palette should be much easier
Matt Overton replied to mr.t.firma@gmail.com's question in Wishlist - Feature and Content Requests
The Attributes Palette is now one of the oldest parts of the program and seriously in need of an overhaul. Newer features have been added over time but none of them ever work in a fluid way. It doesn't work well with palette docking not to mention the odd disconnect between Object Info and attributes. -
Like a balustrade or hob?
New visibility settings
Matt Overton replied to Jim Smith's question in Wishlist - Feature and Content Requests
Stacked viewports are at best a clunky workaround. They clearly fall into the category of easier to get wrong than right. As should be avoidable in day to day production. -
Wall component "library"
Matt Overton replied to JMR's question in Wishlist - Feature and Content Requests
The materials resource discussion noted below did get to a pretty good place in terms of features like you are suggesting. Although I think you've hit on two important ones not covered. -Thickness Most of the materials we use come standard sizes. Plasterboard, Plywood, steelmetal, framing members (steel or timber) have fixed off the shelf sizes. Materials that aren't fixed like concrete still have sizes that very common. Having this embedded in the "material" so we can create wall, roof, slabs more easly would be a big bonus. Auto-naming would be useful too to add into the discussion. -
Return to viewport with Options.
Yes that is better, as the keyboard shortcut would work to get back. -
Matt Overton posted a question in Wishlist - Feature and Content Requests
Ok so only really one option I can think of to start the ball rolling is... 1) when you go to design space from a viewport, if you then adjust classes or layers it would be great if an extra button appeared to match those visibilities in the viewport on return. -
We run VW2016 on some hardware that is low spec. Compared to VW2013 it was certainly an improvement in overall for speed and stability.* That includes moving most projects to at least a minimal 3d model, but also others with reasonably high levels of detail and rendered elevations and sections. Factoring in some new hardware as we get more demanding but it's certainly workable. *one office experience may not be a reliable indicator of another's.
- 2 replies
- 1
- system requirements
- 2016
(and 1 more)
Tagged with:
I often wish VW was more like Apple with it's willingness to pure dead wood from the trees. After all, you don't get good apples without pruning to let the sun in. Apple do trim aggressively and maybe over do it at times. They aren't shy about making developers transition either. Yet in VW old tools that have been rewritten and replaced by much better tools yet the old tools still get pride of place in workspaces and keyboard shortcuts. I think the perception of VW would be better if they shipped a best practice workspace that wasn't shy in moving legacy tools out of the workspace* and moving the improved tools front and centre. * those tools could still work to edit (even duplicate) existing you just would be able to create new objects.
Window Object Glazing Control
Matt Overton replied to Asemblance's question in Wishlist - Feature and Content Requests
Yes, 300mm gap is a very high requirement and generally involves two completely independent frames in what is basically two independent walls. So you could just model it that way if important. Also make sure builder cleans the inside faces of the glass before they put the second sheet in (new client/old problem). That said having multiple glass types as an option would be helpful in many regards, we have 4 colours of fritted glass, switchglass, heavy laminate, double heavy laminate and standard clear in various parts of the same project at the moment. Multiple classes for multiple glass types just doesn't work as fluidly as you'd hope. -
Location information would be helpful to point you in the right direction?
Table and Chairs - Single End Chair
It would be useful if the table and chairs tool had the option for single end chair. 3 person meeting rooms or modular tables in groups. -
Try setting the Heliodon over 100% light and making sure there is no other light source.
plus google will pick up discussions on the forums for trouble shooting and the like.
