good feature.
ps. would help if you lowered the background music when someone is speaking !
pps - I wanted to see stair, window, door updates first ......
that would be my process - ie. build the existing (ie. survey) , save as a new drawing for new works and revise model (put survey on a layer for reference in new model)
so C4D 21 is going subscription based........ and one version only ....
https://www.maxon.net/en/products/cinema-4d/integration/architecture/vectorworks/
@CharlottePea you'll probably have to import them in for your 3d model , the vectorworks MEP ones are useless.
https://3dwarehouse.sketchup.com/model/2c8d01bcaddfa37266147d84ed908c45/UK-Double-Socket?hl=en
I like your optimism!! BUT.... it would appear that the window/door/stair tool is sub-contracted out and not made by vectorworks - users have been complaining for years about these tools but unless the suppliers update their tools nothing happens....
thanks for the file - very interesting that fullscreen preview option adds quite a lot of time to the speed of render - , 28 secs without ; 38 secs with full screen preview.....
with maxon acquiring redshift (and a metal version coming), have to hope this will eventually filter down to vectorworks through cinerender?
also, can't see the point of a mac pro for vectorworks? seems to be like using a ferrari to go to the local shop !!
I'm getting a lot of spinning ball when trying to do polygon fills in viewports with SP.3 (mojave)
Also getting an occasional crash when trying to add polygons together , get this odd object info box as below and have to force quit.
try it on a blank file with framing member = spinning ball of death.... (mac and mojave user)
locks into a freeze and takes about 5 mins before I can use it (even worse on existing files) , see circled area where it seems to lag
I'm trying to use a custom symbol made up of 3 others windows + a door to make custom front door....
I cannot get the walls to be correct (in plan) and I suspect I'm missing a simple trick! Elevation is correct though!
yes, the spinning ball of death has returned for me also (mac) in the last week , anything that requires a detailed object info menu , (stairs, elevation benchmarks) is now causing a hang...
