fabrica
    351
Everything posted by fabrica
  1. warning - RANT incoming ! I don't understand why the section marker has the viewport link at the top of menu and the elevation marker has it at the bottom !! both are always on the same drawing but I find myself having a WTF moment each time ... RANT over....
  2. @Christiaan no problem , it won't let me upload the apple icon version to forum (file format!) but png attached - Hex is : #A2B386 if needed! logo_2021.zip
  3. the new handles for setting image size in 2021 are even worse than previous versions , my mouse pointer needs to be a good 20mm from the actual line for it to work, + the scale line is smaller than ever, handles at each end of line smaller and only right seems to be selectable, its way to hit and miss at moment.
  4. yes, mac. I find it needs to be detached from any other pallets to dock it first.
  5. Could you make your lines 1x1 extrudes in vector works or c4d?
  6. @Jonnoxx i didn't know about blender BIM, this on their wiki made me laugh =: "A small commercial building project was first designed in Blender. We were then faced with the task of remodeling it in Autodesk Revit. We figured it would be easier to build an entire BIM application and construction documentation tool from scratch rather than face the pain of remodeling it in Revit. It turned out that it was." as for vectorworks 2021... due to the last couple of releases I'm resigned to having low hopes , seems too many of the tools are reliant on third parties or abandoned after first release. The marketing version will be good though!!
  7. I use single pane mostly, but have a keyboard shortcut (CMD-L) for a 2 pane. (70/30 split) It goes haywire very quickly when working between viewports etc, hence the shortcut to flip in and out. If it was usable like the C4D one then I'd use it more often.
  8. I normally use the dissolve or melt option to try and get a single polygon - but its generally a mess of triangles by vectorworks, anything curved or circular is worse! I gave up on arnold because it was too complicated for my needs, How do you find it? Do you have any images you could post?
  9. 🤣... Pints for all it is !
  10. brilliant! virtual pint on the way to you once pubs open again!
  11. I cannot figure out how to get the size of a steel (wide flange 3D) into a new data tag , looking to make a simple tag with steel size and length ? Can get the length ok but not the size (ie. the 203 x 203 x 46 part)
  12. you could use the pillar tool in AEC menu also - gives you a solid fill in 2d
  13. 1 - you may have to use two roofs? 2 - it might be easier to 2d model the birch panels and extrude rather than use walls , use internal elevation tool for reference 3 - in the classes of the door object you can set different internal & external textures
  14. fabrica
    Joining Walls
    you might need to 'remove wall breaks' first - should work though? or manually disconnect walls and use wall join again?
  15. fabrica
    Joining Walls
    use the wall join tool , T join and capped option
  16. @Taproot also these two : https://texturehaven.com & for HDRI's : https://hdrihaven.com
  17. My defaults are https://www.textures.com/ and https://www.poliigon.com/ , the 1k textures on textures.com fine for vector works
  18. Should work fine if your roof layer is above your wall layer , post a problem file to have a look?
  19. @bcd very impressive renders , equally impressive Lumion Pro price !!!
  20. theres 5 keynote videos ? which one has the new renderworks features?
