Travis.Designer
69 -
Reputation
15 GoodPersonal Information
Location
Vietnam
Recent Profile Visitors
Hi Can you give more detail about this tool. Thank
Hi I misunderstand why simple feature Hide object lack in Vectorworks? Are there anyone request Hide feature before?
Hi How can I hide a wall temporarily? When I try Visibility Tool, they only hide Class or Layer Thank Travis
Need advice layout many piece of wood
Travis.Designer replied to Travis.Designer's topic in Solids Modeling
Thank Benson and Kevin for advices. I would export to Inventor. It's easier for layout and cnc. -
Use Wacom intuos tablet with Vectorworks?
Travis.Designer replied to Travis.Designer's topic in General Discussion
Hi @hollister design Studio I also confront delay when use space + ctrl = zoom. I think this general graphic problem of Vectorworks. How Vectorworks show graphic and navigation are different with 3DS Max, C4D and more 3d software. This is my wacom setup: I change Right Click in lower button because we use RMB frequently and when press lower button it make pen less moving than Higher button. Higher button I will use to orbit. -
Hi Claes, It work in case because I have 2 similar nurbs curves. What if we have 2 different of nurbs curves?
Hit Stanford Previously, I select 2 lines then Convert to NURBS, they will be Group. This time, I select each line, convert to NURBS. then select 4 nurbs Compose. It work good. However when I Push. It become like picture below: What happen? It's not solid (changed to OpenGL view)
Hi I model many piece of wood as picture below: I need to layout each of them into 2d then documentaton. How can I do it? Thank
Hi I intent to use Push/Pull tool to make solid I try drawing 2 lines to cap then Compose 4 object but it's not work. Need advice. Thank Travis
Thank @Art V First time I know Space + Ctrl = Zoom. It's helpful when we work with Wacom tablet. -
Hi I'm using Wacom intuos tablet with Vectorworks. Currently I have to use C key to zoom. In Cinema 4D, I just hold Ctrl + Alt + drap Right Mouse Button, I can zoom In/Out. In Vectorworks, If I press C key they will exist command which is activing. It's not good because I have to zoom then press the previous command again. Are there other solution? When Vectorworks support Wacom Drawing Tablet? It become popular nowaday. Thank Travis
