Boh
1,704 -
Everything posted by Boh
Snap to Object Deactivates When Rotating an Object
Boh replied to MTRobin's topic in General Discussion
I notice the "snap to working plane" mode is activated as well as the object snap being deactivated. So it definitely seems to be a 3d issue. Have you tried it in different plane options? Is it file specific? I though it might be this: But I can't seem to reporduce your issue. Sorry I can't offer any more suggestions... -
Hi Matt. Here is a sample file with a couple of page based symbols. I've checked and the bounding box is no larger than the visible objects. It seems to happens on most of my page based symbols on both vw2018 & vw 2019. The odd ones whose thumbnails do look ok, if I 'edit' them the thumbnail will then change size, even though I haven't actually changed them -. just gone straight in and out of edit mode. In the screen shot example below the thumbnail got bigger after 'editing'. Doesn't work for most of them unfortunately. It will be interesting to see if any of this behavior happens on your machine or on a new file into which you have imported the symbols. Thanks again for your help. Page Based Symbols Sample.vwx
Me neither. I convert to polygon and hide the edges with reshape tool.
- 3 replies
- line type display
- 2019
(and 1 more)
Tagged with:
I recently posted a seperate thread re page based symbols showing way too small in the RM. I’ll be following this thread with interest.
Tha hatch editor is not very user friendly. There are lots of hatches available in the vw library. It would probably easier to use one of them. Or a similar one you can edit. Creating from scratch something like that is not so easy
That is odd. Does it only happen in 3d projections? -
What are your short cut keys for snapping set to in your workspace? I suspect you might be toggling the snap off somehow on your keyboard. I only have a quick key for turning off and on the grid snaps. -
Drop locus at center of 2 points
Boh replied to MTRobin's question in Wishlist - Feature and Content Requests
You can use the move by points tool: Media1.mp4 -
I suspect there is some detailed 3D geometry slowing the VP updates. I had the same thing happening and then discovered it was some curvey custom door handles with I had inserted. I turned their class to invisible in the vp and the renders speed was back to normal.
- 5 replies
- section viewport
- v2018
(and 2 more)
Tagged with:
Using page based symbols for construction details is a bit problematic as the detail would typically have real world objects in them which, when inserted would scale up or down to suit the VP/DL scale you are working in. You would then have to re-scale the page based symbol back to a real world dimension. This has got m thinking though and a possible workaround using page based symbols could be: Create the detail at 1:1 scale i.e. on a 1:1 design layer with all the text objects, (including callouts, dimensions etc) the font size you want on your final drawings. My standard font size is 14pt so I would make all my text objects 14pt. (The text may look out of scale in the symbol but stick with me here...) Create the symbol as a page based symbol with 'convert to group' selected. After inserting the symbol go modify>scale objects> and scale to the required real world size. Be sure to have the 'scale text' option unchecked. If it is inserted into a 1:5 design layer then it will need to be scaled down to 1/5th the size as per example screen shots below. The detail should now be at the correct real world size and your text at your standard font size. Note that text width may need adjusting and also real world plug-in objects, like the wide flange steel column in the example below, would still insert at it's actual size despite being in a page based symbol. I'd be interested in any thoughts on this option as I'm just about to start looking at creating detail symbols for our office library. Example screen shots:
It may be something to do with page based or world based symbols?
objects unelectable in classes when changing views
Boh replied to mattOC's topic in General Discussion
I had a quick look and it seemed to be working fine for me. I noticed the none class was greyed but it stayed on visible when I changed it. Tried restart? -
PROBLEM - Drafting in Color / Publishing Black & White
Boh replied to CW2020's topic in General Discussion
I don't use B&W files anymore but when I did I often used single colour gradient fills instead of solid fills as the gradients would print in grayscale in B&W. -
Yes, I've noticed this too. It seems to be the case for me on both VW2018 & 2019.
Line weight and EAlexander will have there good reasons for using 1:1 design layers however I think the supposed 'best' practice is to set your design layer scale to the scale you will use for your main drawings. E.g. If most of your plans are at 1:100 then set your design layer scale to 1:100. That way line weights, line styles, arrow heads, page based symbols etc will scale the same in your design layer as they are seen in your viewports. Text will also read the same size, so 14pt text on a 1:50 design layer will look the same size as 14 pt text in a 1:50 sheet layer viewport. I remember my days using autocad where I had to increase the font size of text in the model space to match that on the drawing. Design layer scale in VW does this for you. If you are doing 2d work then you might have a design layer set to 1:25 for sections and elevations and design layers at 1:5 or 1:2 for detail drawings.
Yes I think it depends how complicated your projects are. Using file referencing on a small one off project seems overly complicated to me. If the template is for small projects then it is more straight forward to avoid referencing. You may need to get a system for managing multiple classes, otherwise it can be a bit confusing. My tips are: Have a standardised class system for your templates. Set up your template viewports with the preferred class visibility and override settings. If you are importing third party files then a great little tip is to add a "z-" prefix to their classes. They will then drop to the bottom of your class list out of the way. (There is a script that does this.) Note that classes are primarily used for setting visibilities of different types of objects as well as standardising their attributes (line type, weight etc). Generally, for objects placed on sheet layers you want them to be seen, so setting class visibities isn't important. Most of my sheet layer objects are on the none class.
How to 'fill in' ground around foundations etc, in section drawings
Boh replied to line-weight's topic in General Discussion
Haven't tried it but what about stacked section viewports? One just for the DTM and the other for your bldg model. With two viewports you could set the attributes of each differently in the "Advanced Properties". -
With auto-classing now off any new plug-in objects you put in in your drawings will just go on to the active class so be carefull there. I was thinking the other way you could do it would be to turn the gable window into a symbol and insert the symbolled window into the wall in your invisible class..
If you have autoclassing enabled then window objects will stay on their auto-classed class. File>Document Settings>Standard Naming and uncheck "Enable Auto-classing". I may be wrong on this as I don't use auto-classing or even window objects...
I think you need to simply put the window object in the invisible class. Not change the window classes in the window settings. If the window "container" object is in an invisible class all of the objects in the window will be invisible even if they are in different classes.
Here's a few things we have incorporated into our templates. I'd be interested to know what other people do. Default Design & Sheet layers to the preferred page set up Sheet layers complete with title blocks, scale bars, north points etc and commonly used viewports with class/layer & override settings Default commonly used classes. Default settings set up for all commonly used tools. Units & document adjusted to preferred settings. Often used scripts. Snap settings set up to preferred defaults. We don't generally include symbols as these can be quickly imported from our symbol library. We started off with just a single general template and kept tweaking it to get it how we want before creating more project specific templates.
Hi Scott. Perhaps post the file so we can have a look at it?
