Hippocode
    801
Everything posted by Hippocode
  1. Because that's just not available. A record field is just a parameter holding a value, nothing more. Some fields allows intern calculations but they are not aware of other fields. It would be a simple script, iterating all objects containing your record and do the math manually, save it in one of the fields.
  2. What about creating a worksheet and combining both into one cell ? If that is not what you are after create a script that does that calculation for each object.
  3. I think every object has it's own index, an ID. It's not the same as the unique name string that can be found in the info palette. If you were to create a string, it's actually not so hard. Just a do while loop that creates a random string and checks to make sure such object does not exist, if it does it will continue looping for a new string.. I have some code lying around that handles connecting object by placing a reference into a record attached to it, but it's made with the SDK so you can't do anything with it in vs
  4. Yes, the association is just used when deleting them. Nothing more. What you request is only possible with custom made objects, as you will need to hardcode such behaviour. Depending on your exact needs, you could create some scripts for it as well. The logic behind it is very simple. You can give every VW object a unique name. This name can be used to get a handle to the object. If you would create a script or an object, object A should remember the name of Object B so it can get the handle of it whenever required.
  5. Are you sure it's supposed to be an int ?
  6. What you are requesting is something that has to be hardcoded in the plug-in. The space object for example can do this. You can choose which parameters appear on the OIP. If you do not have the option for the door, then there is no way of doing it.
  7. Yes I'm heavily working on releasing the 2016 version any time soon. Once released I'll announce it in the third party forums.
  8. Maybe a valid workaround is to create a viewport based on the view settings ? I had a script that created unlimited A4 sized pages (based on input), added a viewport that scaled down to fit into the drawing border frame and lastly printed each page to PDF. As I ended up with a lot of presentation layers I didn't need afterwards I changed the code to use only one predefined presentation layer and to switch the viewport settings for each iteration. The only difference with what you need are additional class and layer settings to be saved into the viewport. Maybe that even works by just creating the viewport after loading the view instance.
  9. From what I understand VRestore should load a saved view. Which part didn't work, the view restoring or the printing ? What did it print ?
  10. I believe I had a similar issues with one of my custom batch prints. I advice you to make sure that the "page" you want to print is active, if not force it by code.
  11. Vectorworks stores dimensions in WorldCoord which at this point is equal to one mm. When you used 50cm in VS it would automatically convert it into 500. Regardless of the unit settings, that is the value, always. When showing the coordinates to the user, the value is modified based on the unit settings, but the length is always the same. Can't this function do the same ? http://developer.vectorworks.net/index.php/VS:Str2Num
  12. The sum only combines listed items based on a shared value on the colum you assigned the SUM. You can't just select and choose to combine items. A workaround is to give those you want the combine the same value for a certain attribute/fieldvalue... and use the SUM there.
  13. The easiest way is just to copy the worksheet into excel.
  14. I don't think so. Maybe you could generate a fairly simple script to do that for you: - Read the header and data line - Create a presentation sheet our output location - Print until you reach the height of your presentation sheet frame - Next sheet...
  15. Can you confirm that nothing is selected when you modify the record field settings ? That can be the only reason why it isn't working. If you do have something selected you are modifying data attached to the objects inside your symbol, not the symbol definition.
  16. I'm pretty sure this is impossible, unless the tool saves its settings into the active document which you could change prior to calling the tool. IF that is the case, the tool should remember your last setting when you close VW and reopen the same drawing. Most cases, this is a private setting in the tool event sink and can't be changed manually. This is intended behavior. The PushAttrs command has nothing to do with tool modes / settings.
  17. It is not possible to manually save those settings but it isn't required anyway. the CallTool command just activates a tool and will do anything the tool is programmed to do, including keeping track of it's settings. I've tried your script and the tool settings are saved without any problem. I see you are using 2016, might be related if anyone else can verify.
  18. I'll release the next one upcoming weekend.
  19. I don't think there is an easy solution as you would have using excel. Keeping that in mind wouldn't it be easier to create a worksheet showing each length in a seperate column and porting it into excel ? On the other side you can create a separate if(.a1 == 25)... criteria for each field or you use a script to print the data instead.
  20. Sadly for you, there is nowhere a field saved that holds the index of the last added revision. There is a solution for you but you would need to use a script to find the last used index by traversing the list until you find an empty one...
  21. Pas possible. The best thing you can do is to write a script that sets the current date into a field of your drawing border. In fact you could even add the publish command to it as well so you have your custom command that sets the correct date, then prompts you the publish dialog. This makes sure you don't forget to set the correct date prior to publishing. On the other hand, there are some tools running around the web offering such capabilties, for a small price.
  22. VS has some conversion functions to handle that. I also believe concat(Real) will do the trick. For the CP, just add them as a parameter and instead of creating the text at 0,0 you use the coordinates of that CP. The coordinates are 2 real parameter fields
  23. I really like the new logo. Reminds me of the movie V for Vendetta .
