Michelvh Posted September 29, 2020 Share Posted September 29, 2020 Every texture I try to edit does this whether it originated as an image or color. See the third and last image It did this to me all last year (VW 2020) as well. Unfortunately I was not very busy for most of the year. VW 2021 is doing the same thing. Through the images watch the previews of Wood Decking Red tint. Thanks Quote Link to comment
0 rDesign Posted September 29, 2020 Share Posted September 29, 2020 On the Edit Texture pane, on the right side under ‘Preview Options’ if you change the Obj Type to anything besides ‘Plane’ does it change the preview? Quote Link to comment
0 Vectorworks, Inc Employee Dave Donley Posted September 29, 2020 Vectorworks, Inc Employee Share Posted September 29, 2020 Yes I am wondering the same, if it render with different object type choices. Does Renderworks fail for you in other cases besides this one with the Edit Texture dialog? Quote Link to comment
0 Jeff Prince Posted September 29, 2020 Share Posted September 29, 2020 @Michelvh I've seen this happen before. Hit this button and see if your problem goes away... 2 Quote Link to comment
0 Andy Broomell Posted September 29, 2020 Share Posted September 29, 2020 This happens for me every time I edit or create a texture while inside Symbol Edit mode. This bug started in 2020 and persists in 2021. VB-172583 Quote Link to comment
0 Vectorworks, Inc Employee Dave Donley Posted September 30, 2020 Vectorworks, Inc Employee Share Posted September 30, 2020 Hello Andy: The symbol edit detail is important to know. Can you attach a specific file with a symbol you are editing to the bug? Thanks for the testing!! Quote Link to comment
0 Andy Broomell Posted September 30, 2020 Share Posted September 30, 2020 No problem - I'll attach a file to the bug report on JIRA, but note that it happens in every single file, when in any symbol, working with any texture. It's never not happened, since mid 2020. 1 Quote Link to comment
0 Andy Broomell Posted September 30, 2020 Share Posted September 30, 2020 Update - apparently it somehow has to do with the coordinates of the symbol that you're currently editing. If the symbol is at the origin then the bug doesn't happen. As the symbol moves further away from the origin the texture preview object moves off to the side... and symbols far away from the origin fully exhibit the bug. If you edit the Symbol via the RM then the bug doesn't happen, only if you're editing a Symbol in the document. Attaching a screen recording to JIRA as well. 1 Quote Link to comment
0 Michelvh Posted September 30, 2020 Author Share Posted September 30, 2020 19 hours ago, rDesign said: On the Edit Texture pane, on the right side under ‘Preview Options’ if you change the Obj Type to anything besides ‘Plane’ does it change the preview? It does not but see below Quote Link to comment
0 Michelvh Posted September 30, 2020 Author Share Posted September 30, 2020 18 hours ago, jeff prince said: @Michelvh I've seen this happen before. Hit this button and see if your problem goes away... DING ding ding ------- Jeff wins the prize. That fixed all but one (which has some weird settings) Thanks 1 Quote Link to comment
0 Michelvh Posted September 30, 2020 Author Share Posted September 30, 2020 18 hours ago, Dave Donley said: Yes I am wondering the same, if it render with different object type choices. Does Renderworks fail for you in other cases besides this one with the Edit Texture dialog? That would be a no on that with the object choices. I work almost exclusively in Open GL but the textures did all appear correctly on the design and sheet layers Quote Link to comment
0 Jeff Prince Posted September 30, 2020 Share Posted September 30, 2020 50 minutes ago, Michelvh said: DING ding ding ------- Jeff wins the prize. That fixed all but one (which has some weird settings) Thanks Glad it helped. I wish I could explain why it happens and why my solution works... Quote Link to comment
Michelvh
Thanks
11 answers to this question
