Bruce Kieffer 158 Posted October 8, 2017 Trying to render with Renderworks in a design layer. Blank screen. I see my objects if I zoom, but then blank screen. Quote Share this post Link to post
0 zoomer 1,078 Posted October 8, 2017 Hmmh, I am used to read about "Black" RW Renderings - but "Blank" is new. I can render my design layers with RW so far in VW 2018. (maybe blank is the new black) Quote Share this post Link to post
0 Bruce Kieffer 158 Posted October 8, 2017 It's a mess. I reinstalled VW 2018 to no avail. Now all my RW options are gone. Calling VSS tomorrow! Quote Share this post Link to post
0 AlanW 527 Posted October 8, 2017 Yes I still get this on one of the Windows 7 computers at work. Happened at release of 2017 was sent a file that fixed the other 6 computers but not this one. If you get to solve it let me know thanks. Quote Share this post Link to post
0 Rummelplatz 2 Posted October 9, 2017 Try the following: 1. Delete/Rename your user folder MAC: Library > Application Support > Nemetschek > 2018 change it to _2018 or something else Windows: type in %appdata% in a explorer window find that 2018 folder and do the same thing like delete or rename The user folder will be created on startup again! Don't worry :-) 2. Change to Basic and Back to Designer > Workplaces Quote Share this post Link to post
0 Bruce Kieffer 158 Posted October 9, 2017 The problem is related to CineRender. It is crashing. I spoke with VSS this am. They are working on it. Quote Share this post Link to post
0 Bruce Kieffer 158 Posted October 12, 2017 Is anyone able to render with RW using a 2016 MacBook Pro 13" Touch Bar? Quote Share this post Link to post
0 zoomer 1,078 Posted October 12, 2017 Hmmh, I can render on my Mac Pro. 13" Macbook Pro do not have a discrete GPU (?) But RW Render itself does not work by GPU at all so there is no reason why it should not work like my Mac Pro, beside the speed - or too less RAM for your Projects. But 16 GB should be enough. The only reason I could imagine that you start RW Render from an OpenGL View, as OpenGL uses GPU. And maybe the switch to RW or the geometry creation/export from OpenGL to RW is influenced ? Have you tried to start from a wireframe 3D View ? Quote Share this post Link to post
0 Bruce Kieffer 158 Posted October 12, 2017 (edited) 2017 RW renders fine on my MacBook Pro 13" Touch Bar. Zoomer, I have tried all of the things you suggested. I tested on my Guest user and in safe mode, still no RW rendering. Edited October 12, 2017 by Bruce Kieffer Quote Share this post Link to post
0 zoomer 1,078 Posted October 12, 2017 So that sounds like something with went wrong with VW 2018 installation/access rights ? Quote Share this post Link to post
0 Bruce Kieffer 158 Posted October 12, 2017 I have reinstalled it once. No fix. Quote Share this post Link to post
0 zoomer 1,078 Posted October 12, 2017 I wonder why it crashes on a MBP but not on my MP. But if they already found a problem they should also find a solution. But will need some time until SP2 will be released. Quote Share this post Link to post
0 PVA - Jim 2,389 Posted October 12, 2017 Renderworks seeming to have vanished is not hardware or OS specific. It almost always ends up being related to third party app conflicts if it isn't permissions based on the user account. If Tech already has the case in hand it then they'll find it. Quote Share this post Link to post
0 Bruce Kieffer 158 Posted October 17, 2017 I need to ask again, anyone with a MacBook Pro 13" Touch Bar can you render with RW? Quote Share this post Link to post
0 PVA - Jim 2,389 Posted October 17, 2017 2 minutes ago, Bruce Kieffer said: I need to ask again, anyone with a MacBook Pro 13" Touch Bar can you render with RW? Yes, two versions of that model here render fine, it is not related to that hardware configuration alone. Quote Share this post Link to post
0 PVA - Jim 2,389 Posted October 17, 2017 41 minutes ago, Bruce Kieffer said: I need to ask again, anyone with a MacBook Pro 13" Touch Bar can you render with RW? UPDATE! Bruce you were closer to correct than I suspected! It's isn't specifically the Mac Pro 13" with Touch Bar, its the models limited to the Intel Iris 550 GPU. Specifically MacBook Pro model 13,2. The current line of 13" Apple MacBook Pros would be unaffected (they use the 600 line from Intel), but any that were fitted with the Intel Iris 550 GPU and not a dedicated graphics option are going to encounter this problem. Engineering tracking this bug as critical now. VB-145827 Quote Share this post Link to post
0 Bruce Kieffer 158 Posted October 17, 2017 Thanks Jim. Mine has the Intel Iris Graphics 550 1536 MB. How did I get to be so lucky! Quote Share this post Link to post
0 Bruce Kieffer 158 Posted October 17, 2017 Support found a solution. I can render! Quote Share this post Link to post
0 chris cox 3 Posted October 17, 2017 (edited) On 10/9/2017 at 10:14 AM, Bruce Kieffer said: The problem is related to CineRender. It is crashing. I spoke with VSS this am. They are working on it. I am having the same issue. Did they ever get yours resolved? Note: I am using a PC not a mac. I too have uninstalled and then reinstalled and it worked for a few hours then quit. Edited October 17, 2017 by chris cox Quote Share this post Link to post
0 Bruce Kieffer 158 Posted October 17, 2017 I can't say the solution for my MacBook Pro 13" Touch Bar is the same. Probably not. but they will figure yours out too I'm sure. Quote Share this post Link to post
0 jpoq 14 Posted October 20, 2017 On 10/17/2017 at 11:38 PM, Bruce Kieffer said: I need to ask again, anyone with a MacBook Pro 13" Touch Bar can you render with RW? No problem here rendering with a MBP 15 with Touch Bar. Quote Share this post Link to post
0 Pier Luigi 9 Posted December 21, 2017 We have a similar problem with two PCs running Windows 10 with Quadro video cards. Vectorworks 2018 SP2 shows the RW option just for some seconds, them these options disappear from the menu. OpenGL works as expected. The sad think is the fact that 2017 works on the same computers without any problem. Any hint on how to solve this problem? Thanks Pier Luigi Antonini Quote Share this post Link to post
0 PVA - Jim 2,389 Posted December 21, 2017 7 minutes ago, pla61 said: We have a similar problem with two PCs running Windows 10 with Quadro video cards. Vectorworks 2018 SP2 shows the RW option just for some seconds, them these options disappear from the menu. OpenGL works as expected. The sad think is the fact that 2017 works on the same computers without any problem. Any hint on how to solve this problem? Thanks Pier Luigi Antonini On Windows, If it isnt an issue with a security application quarantining Cinerender (I think Malwarebytes did this sometimes) then normally a reinstallation corrects it. If Renderworks disappears again after that, then get the dxdiag to tech@vectorworks.net and they can take a closer look.https://forum.vectorworks.net/index.php?/articles.html/articles/directx-diagnostics-and-system-profiler-r202/ Quote Share this post Link to post
0 Alexander Thiel 4 Posted January 12, 2018 On 17.10.2017 at 10:36 PM, Bruce Kieffer said: Support found a solution. I can render! What exactly is the solution? Greetz Alex Quote Share this post Link to post
0 Bruce Kieffer 158 Posted January 12, 2018 There's a problem with one of the RW app files and my version of the MacBook Pro 13" Touch Bar, and it's graphics card. Tech support was very helpful and patient. They determined it was an incompatibility that could be fixed by removing a file titled libosmesa.dylib which is inside /Applications/Vectorworks 2018/Renderworks/resource/libs/osx/mesa. That fixed it for me. This is still an issue with SP2 and support is aware. Quote Share this post Link to post
