Random crashes with SP4 VW17
bjoerka
Since i installed SP4 a few days ago, i experience more and more random crashes when doing something really normal like changing the view with keyboard shortcut or choosing a tool with keyboard shortcut or zooming with keyboard shortcut (i.e. command-2)
All crashes that i had the last days always occur after a keyboard shortcut...
Anyone else?
MacbookPro Mid2014, 16gbram, 2.8ghz i7, GeFroce GT750m, MacOS 10.12.5
VW17SP4_report.txt
Edited by bjoerka
13 answers to this question
Anyone else?
VW17SP4_report.txt
 Try changing the performance from best compatibility to best performance ..there are 3 options, just change this and see what happens.
also your 750m might be not powerful enough.. this card from 2013. How many gig ram does it have?
you also might want to check for the this cabinet /application support/nemetschek/2017 ...just change the name, vectorworks will generate a new one with the next start.
you have to access the library..hold down alt when you are in the finder go to menu.
you won't loose anything by changing the name, later on you can copy things when ur missing them.
Edited by Rummelplatz
sp4 is very unstable for me. i guess i will go back to sp3.
getting more and more unexpected crashes also while updating references or saving and committing to project sharing.
also, when more drawings are opened i have problems with screen redraws and visual errors. in 2d plan things are where they are supposed to. in axonometric views everything flies around.
closing other drawings solves the problems.
things that didn´t happen in sp3
the tricks that rummelplatz wrote didn´t change anything.
Currently I don't use heavily.
After an initial unexpected crash it works so far.
Just today I went over a file which works great in Top PLAN view but
shows nothing when I switch to standard "3d" Top View,
although I am in the middle OpenGL mode.
And some problems fitting view and some temporary ignorance of my 3DC Enterprise.
Edited by zoomer
I hate to say it but I think Im going back to SP3. There's something goofy with SP4 where I get beachballed without any typical provocation and yesterday I got a lightening crash when editing the source polygon of an extrude. Very bizarre.
Does anyone know how where to find the SP3 installer?
I'm resisting installing SP3 but I have gotten into the habit of saving & restarting VW whenever it pulls the emergency brake. Happens about every 2 hours. I think it's a memory thing and doesn't seem to matter if I'm working in a 2d only or complex 3d file.
and after the restart everything is breezy again!
Edited by bcd
