- 3
Structural member / column: resets to zero height when 3d attributes changed
Asked by
line-weight
Asked by
line-weight
7150 Riverwood Drive, Columbia, Maryland 21046, USA | Contact Us: 410-290-5114
© 2018 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
Try this in blank document:
Create a column with the structural member tool.
It'll have a Z height, looks like default is layer wall height.
Go to its settings dialogue, "3D attributes" tab.
Change "set attributes:" from "object" to "class".
The column immediately flips to zero height (even if you don't change the "class" from the default) and the "start bound" and "end bound" dropdowns in the OIP are blanked out.
Is this a known bug?
***edited to add:
(1) with column same seems to happen if I change "set attributes" to "class" in the 2D attributes tab,
(2) the beam version of the structural member tool survives these processes.
(3) setting "2D attributes" by class seems to have no effect on rendering of beam in top/plan view. Only setting the class of the object itself achieves this.
(4) with beam, having changed 3d attributes to "class" I can't seem to then change them back to by "object"
Edited by line-weightShare this post
