Tom Klaber Posted September 14, 2016 Share Posted September 14, 2016 Most of those textures are just black. Does that seem correct? Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted September 14, 2016 Vectorworks, Inc Employee Share Posted September 14, 2016 Just noticed that too, no it isn't. Theyre showing differently in C4D: I don't know enough about these materials to know why this set of them would be any different, I'll submit it now just in case. Some are fine and some aren't. Quote Link to comment
0 Tom Klaber Posted September 14, 2016 Author Share Posted September 14, 2016 I tried a bunch out. even the few that are not black - and something seems to be not right with those resources. Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted September 14, 2016 Vectorworks, Inc Employee Share Posted September 14, 2016 Split this off into a known issue thread, bug submitted. Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted September 14, 2016 Vectorworks, Inc Employee Share Posted September 14, 2016 I think the sample file I was using is quite old, as per a comment from @Kevin McAllisterI sent it on to Engineering to confirm whether its something to do with the updated reflectance shaders or something else. Quote Link to comment
0 Kevin McAllister Posted September 14, 2016 Share Posted September 14, 2016 I will say if you're looking for C4D resources and textures, Greyscale Gorilla is a great resource. I've used their textures for years. KM 2 Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted September 14, 2016 Vectorworks, Inc Employee Share Posted September 14, 2016 Apparently the black importing textures were indeed affected by a limitation in which portions of CineRender R16 we can use. Among them the Reflectance channels @Kevin McAllistermentioned. I will try to get a whitepaper together to detail anything else that may behave this way. Quote Link to comment
0 Kevin McAllister Posted September 14, 2016 Share Posted September 14, 2016 Oh, so any textures we use have to be for C4D R15 and older? Reflectance replaced a whole lot of stuff in C4D R16.... so most modern C4D textures (including the Greyscale Gorilla ones) have been updated to use Reflectance. Kevin Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted September 14, 2016 Vectorworks, Inc Employee Share Posted September 14, 2016 Not sure. I''m going to talk with the rendering team to get a list of any known limitations together. Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted September 14, 2016 Vectorworks, Inc Employee Share Posted September 14, 2016 Actually, stand by, I may just be dumb. Apparently there is another method of saving C4D file that includes associated resource and when I made this sample I did not do that, so the sample C4D file I posted does not have the image shaders or other guts that Vectorworks would need in order to display them properly. I'll do a writeup of all of this as well as a suggested workflow for getting the materials from C4D into Textures in Vectorworks. If I have posted erroneous information before now I apologize, I'll speak on this again once I get cleared up. 1 Quote Link to comment
0 rDesign Posted November 15, 2016 Share Posted November 15, 2016 On 9/14/2016 at 0:12 PM, JimW said: Actually, stand by, I may just be dumb. Apparently there is another method of saving C4D file that includes associated resource and when I made this sample I did not do that, so the sample C4D file I posted does not have the image shaders or other guts that Vectorworks would need in order to display them properly. I'll do a writeup of all of this as well as a suggested workflow for getting the materials from C4D into Textures in Vectorworks. If I have posted erroneous information before now I apologize, I'll speak on this again once I get cleared up. @JimW- Have you had a chance to clarify & put together a write-up of the suggested workflow for using C4D textures in Vectorworks? Thanks. Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted November 15, 2016 Vectorworks, Inc Employee Share Posted November 15, 2016 No, I have yet to get a definite explanation that I understand well enough to convey the information to users. Quote Link to comment
0 zoomer Posted November 15, 2016 Share Posted November 15, 2016 51 minutes ago, rDesign said: @JimW- Have you had a chance to clarify & put together a write-up of the suggested workflow for using C4D textures in Vectorworks? Thanks. You can import any C4D File by import C4D "Textures". If it contains standard C4D Materials (no VRAY Materials) it will create a Ressource Folder in your VW file with the name of the C4D file and load these in. If you have already "RW Textures" with same names, it will change the name to "SameName-1". It will load in Image Textures and standard Material values. All 4 VW Material Channels will be set to "imported" but can be changed and edited. As C4D Materials have no Texture size, that happens there with assignments per Object later, you will have to check and assign a proper "RW Texture" size. If C4D Materials used any Reflection Shader other than "legacy Reflection", you will not notice in RM Preview but these will simple Render completely black. In this case you should change the VW Reflection Channel from "imported" to any suitable RW reflection type and it should work. 1 Quote Link to comment
0 rDesign Posted November 15, 2016 Share Posted November 15, 2016 Thanks zoomer - I'll give it a try again. Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted December 6, 2016 Vectorworks, Inc Employee Share Posted December 6, 2016 @Tom KlaberSome engineers are taking another look at this, one or more of them may request access to the google drive link you sent me for testing. Quote Link to comment
0 Tom Klaber Posted December 6, 2016 Author Share Posted December 6, 2016 Thanks. Quote Link to comment
Tom Klaber
15 answers to this question
