With every release I take a long look at the Stair Tool and like many of you I end up using the old 'Custom Stair' tool that we now need to pull out of a legacy list in order to use because it is still superior to the new 'Stair' tool that has been around and updated repeatedly for many versions now. Has it been 5 or 6? I've lost count.
I still find it very difficult to get the configurations I need with the new stair tool where the old interface is very intuitive. I'm also finding that the round elements of the new stair tool render with facets in hidden line while the Custom Stair tool does not.
I suggest trashing the new Stair tool entirely and returning to the Custom Stair Tool and adding the following wishlist items.
1. Each stair run should have a +/- offset from center. In this way we can create two straight runs of different widths that can step around a wall when a stair goes from an open tread to a closed tread on one side. A very common stair configuration. Currently the centerlines must match for consecutive straight stair runs. This also helps on stairs where stair runs are different widths.
2. Give us the ability to select a symbol of a railing profile and have the rail be extruded from this shape. We are allowed to do this with the Stringer Profile why not the railing? The third party Vectordecks has done this for years.
3. Give us the ability to select a symbol of a 3d baluster and have it inserted in place of a basic round or square baluster. Vectordecks does this as well.
4. Add a toggle between square or bullnose nosings with the option to wrap the bullnose to the left and/or right tread ends. Give us the ability to control this in one spot for the whole stair or to control it by stair run. (Wrap bullnose tread left, Wrap bullnose tread right)
5. Tread side extensions should be toggled from the set tread width to align with the stringer offset per individual stair run. (Align Left Tread with Stringer, Align Right Tread with Stringer)
6. Maintain our ability to control the visibility of the handrail and balusters from both the left and the right either in one spot for the whole stair or by individual stair run as it is now.
7. Like the new Stair Tool, align risers to the outside face of stringer instead of the tread width or give us the ability to choose.
8. Like the new Stair Tool, give us the ability to show the entire top tread, just the riser and nosing, or neither.
9. Like the new Stair Tool, give us the ability input the floor depth to set if the stringers extend below the floor or stop at the floor.
10. Differentiate between a structural stringer component and a finished trim stringer component.
Joe
