126 -
Reputation
0 NeutralPersonal Information
Occupation
architect
Homepage
Hobbies
architectural design
Location
ireland
Publish causes application to freeze (cinerender)
Eoin R replied to Josh NZ's topic in General Discussion
We have had problems with publishing PDF files. The issue seems to be when we use the create folder dialogue box in Vectorworks. This always crashes VW. If we create the folder for the PDFs in the main OS and then go back to create the PDF files in Vectorworks all seems to work OK -
Stair Comments and Wishes
Eoin R replied to Joe-SA's question in Wishlist - Feature and Content Requests
+2 Particularly useful with the Custom Stair tool is the ability to set a stairs to appear on two layers set to these levels. We have never used the current Stair Tool for this reason and the interface with the Custom Stair Tool is better. However the Custom Stair has its own weaknesses. The balustrading and handrails in 3D never seem to work well. -
BCD you are right on that small test file switching on the class shows the roof profile. But in our active and larger but not overly complicated working drawings we don't get this no matter how many classes or layers we switch on.
The commands are there in the menu but the roof or roof 'face' does not appear. when the command is activated. The objects are visible in top plan view but not in 3d Files are attached. These were created from scratch.
I am having bigger issues with roofs in 2016. We cannot seem to be able to create or view roofs. Have exported the file back to 2015. Opened it in 2015 all works fine but then roofs disappear when imported into 2016. It is not a class visibility issue.
Docked Palettes Undock After Computer Restart
Eoin R replied to Bruce Kieffer's topic in General Discussion
Has this issue been fixed in SP1 update? We like to docked palettes but after unchecking this so that we can have files open simultaneously we can't seem to get the docked version back -
We are having the same issues on one particular iMac desktop where the visible cursor is offset from an active invisible cursor. It is very frustrating and happens 10-20 times daily. Oddly it is affecting only one computer at the moment. It only started after we upgrade to Yosemite just over a week ago. Any help on fixing this would be really appreciated.
Jim Can you update us on VW2015 compatibility with Yosemite. For other reasons we want to make this upgrade but we need to be sure that it will work with Vectorworks. Thanks
Found the source of the problem. A rogue text block far away from the main model was the culprit. Deleting this appears to make everything work again.
I seem to have accidentally triggered a setting that is making viewing and working in 3D impossible. From a distance I can see the complete model but as I zoom large parts disappear as if there was some limit on how close you can view the geometry. Does anyone know how to fix this? (Many thanks if you do)
Vectorworks 2015 , 64bit and other technical questions
Eoin R replied to PVA - Admin's topic in General Discussion
Are there any improvements in the Door/Window tool? These are crucial to our workflow as architects and the current tools do not work well. Consequently we use Windoor from Ozcad. Can you confirm if this is compatible with VW2015? If not we can't make the upgrade as Windoor is essential to the work that we carry out. The stair tool also could do with an overhaul. Can you confirm if the latest release has any improvements in this regard. -
"Categorically disagree. SP3 Crashes as often as SP2.- No change. 2014 should be renamed CRASHMASTER 2014" This is our experience. VW 2014 SP3 crashing every hour or so most dayswithout any discernible pattern and losing work along the way. We have set auto save to every 5 minutes.
We are having significant crash problems with SP3 and previously with SP2. Hard to figure out why and there is no particular pattern discernible. Sometimes we can go 3-4 hours without any problem but then it can start to sporadically crash every 15mins. As a general comment we have not had this experience on previous versions of the software and SP1 of 2014 appeared very stable but had some basic faults which were rectified in later versions.
Mike Many thanks that seems to have fixed the issue. Although I'm struggling to understand how the file went awry.
We are having an issue in one file where all edges are becoming serrated in Open GL mode. Has anyone experienced this before or have a fix. I have gone through the various settings and cannot find anything can might be the cause of this. Many thanks.
