Tools which provide a protractor to define a user plane often cannot find the normal to a surface. A guide object has to be added to accomplish the normals. I wish for a keystroke or other control to flip, then flop if needed, the protractor through it's 90° plane rotations to set it normal to the easy to find planes. Normal plane should until the protractor is pinned, tool direction/axis is set, and the tool action is complete.
Example shows intended bend of the green planar object. Prior to placing the brown guide object, hovering the protractor around the green surface and its edges produced options on or parallel to the xy plane, and xz plane, but none normal to the xz plane.
2nd wish to correct a Minor Annoyance:
I keep my OS dock on the right side, auto hide. VWX pref for palette margins is set to Both Sides. New drawings emerge with drawing occupying entire screen, palettes both sides concealing portions of the drawing. I wish the palette margin setting was effective. (I know, use a template).
Benson Shaw
OK, getting used to new OS and vwx2015.
1st wish of the new version:
-B
Edited by Benson ShawLink to comment
11 answers to this question
