Michelvh Posted July 23, 2013 Share Posted July 23, 2013 It seems like there is a shortcut of esc esc esc to close a viewport Am I remembering wrong? If not how do I set that? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted July 23, 2013 Vectorworks, Inc Employee Share Posted July 23, 2013 You can use Ctrl+} to exit the Annotation, Crop or return to the VP from the design layer. Quote Link to comment
Kevin McAllister Posted July 23, 2013 Share Posted July 23, 2013 Kevin's shortcut also works for exiting groups and symbols. Its a great shortcut to know. KM Quote Link to comment
michaelk Posted July 23, 2013 Share Posted July 23, 2013 Window > Edit Group Options will let you turn esc esc on and off. mk Quote Link to comment
RicardoF Posted July 5, 2023 Share Posted July 5, 2023 Could this shortcut be made customisable? Cmd+] is not particularly ergonomic. Quote Link to comment
E|FA Posted July 5, 2023 Share Posted July 5, 2023 You can customize the key command using the Workspace Editor. Exit Annotations is controlled by the same key command as Exit Group. So to change BOTH go to: Tools menu->Workspaces->Edit Current Workspace->Menus tab->Modify->Exit Group and change the key command. The specific location under the Menus tab in the Workspace Editor may be different depending on your current Workspace. 1 Quote Link to comment
