Assembly Posted March 17, 2013 Share Posted March 17, 2013 Looking at a new iMac. What are the most important features for VW to run well. I'm thinking: As VW is not multi core, that is not so important. More memory rather than Processor power. How important is the graphics card? Quote Link to comment
Kevin McAllister Posted March 17, 2013 Share Posted March 17, 2013 If you're running Renderworks, everything is important as it sees extra RAM and multiple cores. For every day work in the design layers, the graphics card is important for OpenGL. As long as the graphics card has at least 1GB of video RAM you're probably good as most Apple graphics cards at that level are pretty powerful. And eventually Vectorworks will be 64bit and multi core aware (there was an interview with NV and its supposed to appear in VW2013 or VW2014, clearly they missed VW2013). Kevin Quote Link to comment
P Retondo Posted March 17, 2013 Share Posted March 17, 2013 If you're working in 3d, in order of importance, processor speed (multi-core good for Renderworks), video card (speed and cache size), min 2GB RAM, 4 better. Quote Link to comment
Jonathan Pickup Posted March 17, 2013 Share Posted March 17, 2013 nothing beats raw power, so the best processor you can afford, then as much RAM as you can afford, but watch out for the graphics card. unless you are looking at one of the special apple laptops, you can add ram later, but its not always possible to upgrade the processor. Quote Link to comment
grant_PD Posted March 18, 2013 Share Posted March 18, 2013 RAM and graphics card, send your files to VW cloud for processing power. And a nice, big, monitor. Quote Link to comment
Assembly Posted March 18, 2013 Author Share Posted March 18, 2013 I'm pushing my VW on the BIM side. I get a lot of slow down in my files as I add more Viewports and Section VP's. I find that the annotation part of a viewport changes as file size increases. With Hidden Line Renders, Small files maintain the hidden line render when entering annotation layer. Large files revert back to wireframe. I suspect this might be a memory issue? So with large files I'm wondering if more memory is better. Simply put is it the case that VW maxes out the memory, and when it does it has to do more processing?. For the same money I could have a 2.9ghz, 512mb graphic, 32Gig memory or 3.2ghz 1Gig Graphic 8 Gig Memory. Quote Link to comment
Jonathan Pickup Posted March 18, 2013 Share Posted March 18, 2013 quad core or dual core? Quote Link to comment
Jonathan Pickup Posted March 18, 2013 Share Posted March 18, 2013 512MB graphic is the minimum, so it would eventually have to be upgraded. Quote Link to comment
Dieter @ DWorks Posted March 18, 2013 Share Posted March 18, 2013 (edited) The processor clock speed should be as high as possible as VW really rely on this! I have this out of own experience and it's somewhere in the VW documents with computer specs. Graphics card should be min 1GB, and 8GB of memory is more than enough. Edited March 18, 2013 by DWorks Quote Link to comment
P Retondo Posted March 18, 2013 Share Posted March 18, 2013 Go for the 3.2 GHz, mate. 8GB RAM might be more than VW can use at present, plus you can always add RAM later. Are you really using vw2011? Major improvements in viewport update speed since then. Quote Link to comment
Christiaan Posted March 18, 2013 Share Posted March 18, 2013 More RAM helps keep machine zippy with lots of other apps open though so VW itself isn't the only consideration. Quote Link to comment
Assembly Posted March 19, 2013 Author Share Posted March 19, 2013 Are you really using vw2011? Major improvements in viewport update speed since then. yep 2011 Given the higher spec requirements of VW2013, there is quite some cost to move the entire office up. I know there is background rendering of VP's what else is there that increases the speed of vps? Do your hidden line VPS stay hidden line when you edit the annotation? Quote Link to comment
michaelk Posted March 19, 2013 Share Posted March 19, 2013 Do your hidden line VPS stay hidden line when you edit the annotation? Probably a dumb question: Do you have Display Viewport Cache selected? mk Quote Link to comment
