Closed Polyline
Kaare, I tried what you describe with a sample Polyline.
It worked with a "slight" increase of verticies.
Before the conversion the Polyline had 7 after converting to a Polygon I got 1281 Verticies.
Seems to be the famous "Lehman Brothers Algorithm" behind that Process.
Edited by Horst M.
To Horst: Well you are not going to send the polygon to CNC - it is only meant for inspection.
To BCD: The extrution method may not be foolproof. It catches faults due to open polylines, but it does not catch potential faults due to invisible segments in the polyline, as they become visible in the extruded object.
The CNC software may not mind invisible segments, but then again it may. So to be sure, go with my method, Bruce.
