  • 2
Snapping stops working when editing deeply nested objects.
Bruce Kieffer
I have symbols nested inside of other symbols, and solid objects nested inside other solid objects. When I go to edit them, at a certain depth of nesting object snapping does not work. It's like three or more levels in. Is there a way to make object snapping work in this situation? Is there a workaround?
10 answers to this question
Hmmh, I think for my imported IFC Container Objects, snapping did not
need a nesting level to fail. Or maybe there was another group in there,
so one level.
I do not know of any workaround. I collapsed the Containers ....
But that doesn't sound like a solution.
Edited by zoomer
I've noticed this too + have never really understood what was going on. Perhaps inside a Group inside a symbol in my case...? Not being able to snap to objects outside the Group? Quite annoying. I think if you can reproduce it you should file a bug on it + see what they say.
I just tired to create a simple file to send you @rDesign that would show the snapping problem. I opened a new blank file and placed a symbol that I have trouble snapping in my complex file when I drill into the symbol. No problems in the blank file, but still problems in my complex file. I don't know how to show you this problem easily. I will send you a file someday if I ever figure out how to reproduce it simply.
The only reprieve I have had from this issue and it doesn't always work is to change to wire frame.
It is like forcing an update in a viewport when trying to dimension in hidden mode and the snaps stop appearing.
  • Like 2
I have found the same over here
