Kevin K Posted February 10 Share Posted February 10 I will probably rue the day I brought this up. 🙂 Some of you may recall my last great idea pertaining to a 'Vectorworks Store"....that went well ! 🙂 Anyway, here goes.... Personally, I REALLY value feedback along the way, for any of my designs, which are usually in the arena of Residential Design, with some Commercial and Furniture Design thrown in now and then. We often get so close to our design work that it sometimes becomes the 'forests for the trees' scenario. We get so close and focused that we , certainly I, miss obvious things. A quick example...I have a good friend who was having a Client meeting for a new home design. He was pointing out various things to his Client and the woman said "David, the master suite is just fabulous...but don't you feel it would be a good idea to have a toilet in the master bathroom"? That is my point. In the heat of battle he just forgot the toilet!! Had someone else, with a fresh set of eyes, looked at his master bathroom plan, they would probably have noticed that immediately, right?? So...what ya think?? Would this fly to have an area on the Forum for folks to discuss their designs, etc and receive feedback from others? Or is this really bad idea ? I will go first.....have at it... I was just working on a rendering for a sort of Renaissance dining room. Back then they had no actual electrical lighting, so they used a lot of candles, oil lamps, etc for general lighting. Pertaining to this Rendering...where did I go wrong, or what may be missing or just not right? Don't be shy...I have very thick skin! 🙂 1 Quote Link to comment
Kevin Allen Posted February 10 Share Posted February 10 well, the color temperature of the 'candles' is too cold 2 Quote Link to comment
Kevin K Posted February 10 Author Share Posted February 10 See Kev!! that is exactly my point.....you saw that immediately! Quote Link to comment
Kevin K Posted February 10 Author Share Posted February 10 I also have a disadvantage in that I am horribly color-blind 😞 1 Quote Link to comment
Jeff Prince Posted February 10 Share Posted February 10 (edited) If you are going to use a Vermeer painting, you might want to warm up your lighting 🙂. Looks like a commercial interior lighting wise. Fireplace should be producing a warm glow too. Edited February 10 by Jeff Prince 2 Quote Link to comment
bcd Posted February 10 Share Posted February 10 Yes, the light is where it's at in a scene like this. You will get most of the light from the fire - the candlelight will be very localized & there should be much more shadow where shadows would naturally fall. Quote Link to comment
Tom W. Posted February 11 Share Posted February 11 @Kevin K if you clear the plates away you could fit even more wine bottles on the table 🙂 1 Quote Link to comment
VIRTUALENVIRONS Posted February 11 Share Posted February 11 Did you Render this in Vectorworks or CINEMA 4D. Either way you have done a great job. The only area I see that could use some attention is the low level lighting and by low level I mean "under the table". It seems the light sources have not reached that area to produce shadows from the legs, etc. As that is the focal point, the eye is drawn.. But, the detail of your work is incredible, truly amazed. 1 Quote Link to comment
bcd Posted February 11 Share Posted February 11 (edited) A lot of cool modelling here. I would also choose a different texture for the stone floor. It looks like cobbles that have been scaled up, resulting in the grout relatively too wide and the displacement too large. In a setting like this I would expect to also see an area rug. I'm curious why we can see out one window but none of the others. Could it be to do with the reflectivity/ transparency settings of the glass texture? ...because a vision softly creeping... Edited February 11 by bcd 1 Quote Link to comment
Kevin K Posted February 11 Author Share Posted February 11 First, you guys did a great job with your various bits of feedback! Much of which was all perceptive positive stuff and definitely appreciated. This is sort of where I was going in suggesting there be a place on the Forum for such discourse. @Kevin Allen was totally spot on about the candles being a bit too cold looking...I messed with them a bit . Paul, the scene was rendered in C4d and Redshift. You may be correct about some additional lighting under the dining table, although with, in this case, being just before dark outside, I am not really sure how much light would actually find its way under the table. I certainly could just create a bit more by placing a very dim area light under the table to procure that. Good point, none the less 🙂 @bcd, your comments were also valuable and duly noted 🙂 In this Rendering it really is all about the lighting. The stone floor is some old, beat-up cobble stone, which I was thinking would be appropriate to what was going on in those days, but that said another texture could be used. Area rug?...definitely didn't think of that 🙂. Like perhaps a large one under the dining table?? The reason it seems like you can see out of some windows and not others, is probably because of the HDRI background I chose. Some of it, which you could see in the daylight, was very dense with trees and other areas not as many trees, which, to your point is why it appears as you noted. Always a tough choice in choosing an HDRI background 🙂 I turned the brightness wayyyyy down to get the sort of twilight, early evening, exterior environment feel. I could make the time or day a little earlier so you could see more out the windows 🙂 You did a good job darkening the images a bit ! Lots of ambiance there!! Although I would hope you could find your fork if you dropped it 🙂 But all in all, again, I really appreciate all of the comments you guys contributed. So what I didn't hear is whether or not you think it would be of value to include an area of the Forum to do exactly what you all did with your comments, etc ?? It will be interesting to see how and 'if' this resonates with the powers that be if they take note of the post. And lastly...for Tom W who needed more wine!! I think the stone table with all the extra booze was not very visible in those rendered views I posted....so Tom....I even put in some champagne in a bucket for ya...since you are such a refined Brit! 🙂 I made the brightness of the HDRI image a little lighter too so you can see a bit more through the window behind the booze table. Honestly, you can go on and on with small tweaks with this sort of scene. It never stops! You may need to click on the image in the post to see it in better resolution. Btw, for all you students of history, that large piece of furniture on the wall to the left of the booze table is called a 'Vargueño. They were ubiquitous during the 16th century. When I initially mentioned the idea of a 'Design Feedback' zone on the Forum I was not so much thinking about Renderings specifically, but other things, like home designs, etc, but really it would be unlimited in scope. 2 Quote Link to comment
VIRTUALENVIRONS Posted February 11 Share Posted February 11 (edited) As this would be very subjective, it could be difficult to implement on the Forum. The VW store is quite clear, etc. and still a long way off. But, just posting as you did and asking for critique may simply be the best solution. Edited February 11 by VIRTUALENVIRONS Quote Link to comment
Tom W. Posted February 11 Share Posted February 11 14 minutes ago, Kevin K said: And lastly...for Tom W who needed more wine!! I think the stone table with all the extra booze was not very visible in those rendered views I posted....so Tom....I even put in some champagne in a bucket for ya...since you are such a refined Brit! 🙂 Any dinner party where the guests each get their own bottle of wine is fine by me 😁 I did notice the spirits on the side table. Very important to have something in reserve for when the vino runs out!! 1 Quote Link to comment
Kevin K Posted February 11 Author Share Posted February 11 Tom, those folks back then were pretty heavy drinkers…..hence the added consideration of the booze table! Quote Link to comment
Kevin K Posted February 11 Author Share Posted February 11 @VIRTUALENVIRONS, Paul, you are probably correct in your assessment of the viability for what I am proposing……but, you know me….ever the optimist!! Quote Link to comment
VIRTUALENVIRONS Posted February 11 Share Posted February 11 HI Kevin These ideas get people talking about non standard stuff. That is good for the Forum. For the most part, VW's designs have a similar feel. I am sure your images inspired a new user or two to look into high end rendering. 1 Quote Link to comment
Kevin K Posted February 11 Author Share Posted February 11 Paul, seems to me it is always good to raise the bar occasionally:-) Quote Link to comment
Kevin K Posted February 11 Author Share Posted February 11 When I first saw a rendering with a reflection on a wine glass of whatever was in that space…i was hooked!! Quote Link to comment
VIRTUALENVIRONS Posted February 11 Share Posted February 11 When I first saw a "wine bottle", I was hooked😀 1 Quote Link to comment
