snap to angle constraint
Donald Wardlaw
7 answers to this question
6 hours ago, Donald Wardlaw said:
Something has changed, probably something I unintentionally touched.  The snap to angle in the snapping panel is selected.  But it will not let me snap to any angle other than 0 or 90.  No system changes.  VW 2021 on Mojave.  Thanks. Donald  (re-launching VW had no effect).
Also, check in the Angle Snap Settings that 'Angles from axes' is enabled:
You can have Snap to Angle enabled in the snap settings (Screenshot2023-08-16at06_36_41.png.1c57b09178f8b78baee4cf216327ff41.png) but unless 'Angles from axes' is also enabled you will only snap to 0° + 90°
On 8/16/2023 at 1:15 AM, markdd said:
What tool are you using? If it is the line tool, then you may have it in in the constrained mode. I did this a while back and it took me ages to work out what had gone wrong.
Thank you @markdd.  I was having snapping problems, and couldn't for the life in me figure out what the heck I had hit to make my lines only snap to 30 and 45 degree angles.
19 hours ago, Jonathan Pickup said:
like Tom W, i have added the 15º to my snaps. To do this add ;15
There are times when I love having the 15 added and times that I absolutely hate it.  When my drawings get a little too crowded and there are many things competing for those snaps it gets to be too much.  But most of the time i am glad I have it.
