Matt Hagen Posted January 22, 2023 Share Posted January 22, 2023 Hi, I've recently updated to SP3 in VW2023 (Windows) and my Windoor symbols are disappearing on me when i move or edit them. Any ideas please?? Thanks Matt Hagen VW2023 SP3 Windows Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz 4.20 GHz Quote Link to comment
0 AlanW Posted January 23, 2023 Share Posted January 23, 2023 @Matt HagenHi Generally this is an issue with an object being way off in the distance. turn on all classes and design layers and select all. See what you find and delete till you get only the main drawing filling the screen. HTH Quote Link to comment
0 Matt Hagen Posted January 25, 2023 Author Share Posted January 25, 2023 Thanks Alan. Not this time. I reinstalled WinDoor and its sorted the problem. 1 Quote Link to comment
0 Tom W. Posted February 2, 2023 Share Posted February 2, 2023 I'm having all sorts of craziness with WinDoor in VW2023... 1 Quote Link to comment
0 Tobias Kern Posted February 15, 2023 Share Posted February 15, 2023 (edited) Hi, I have also Problems with Windoor under SP3 (German Version) I can't edit Windoor-objects created before SP3 + I can't create new Windoor-objects. If I want to show the Windoor-palette, VW crahes instantly! I de- and reinstalled Windoor I repaired VW with the Updater Greetings from Germany Tobi Edited February 15, 2023 by Tobias Kern Quote Link to comment
0 Tom W. Posted February 15, 2023 Share Posted February 15, 2023 I deinstalled then reinstalled WinDoor + it was OK again after that. But for you it's still playing up? Quote Link to comment
0 Tobias Kern Posted February 15, 2023 Share Posted February 15, 2023 Yes. … I tried all what's in my might to fix it! … no luck, no success. Greetings from Germany Tobi 1 Quote Link to comment
0 zoomer Posted February 15, 2023 Share Posted February 15, 2023 3 hours ago, Tobias Kern said: + I can't create new Windoor-objects. I had that too (in SP 2 ?) But I thought it is just me not knowing how to use WinDoor ... With earliest VW 2023 also problems with the WinDoor Palette, maybe because I had my Workspace migrated. I will try deinstalling/installing .... Quote Link to comment
0 Matt Hagen Posted April 20, 2023 Author Share Posted April 20, 2023 I uninstalled then reinstalled and all is well in the world. Just trying to do that with the rest of my life now 🙂 Quote Link to comment
0 zoomer Posted April 20, 2023 Share Posted April 20, 2023 BTW, for me it is working too. Since I also un-/reinstalled the Plugin lately. Quote Link to comment
0 zoomer Posted April 20, 2023 Share Posted April 20, 2023 (edited) Possible that WinDoor does not create Wall Closures .... although the settings are available !? I have copied out some of my Walls from the building to test with WinDoors. I rechecked all my Closure Settings (use from Walls) But none of any WinDoor element shows Closures for me, while the VW Windows and Doors beside, in the same Walls do .... All WinDoors are labeled as WinDoor in Wall. Edited April 20, 2023 by zoomer Quote Link to comment
0 Tom W. Posted April 20, 2023 Share Posted April 20, 2023 54 minutes ago, zoomer said: Possible that WinDoor does not create Wall Closures .... I do not use WinDoor much + never before with Wall Closures I don't think but I have tried it quickly now + it is working for me... Quote Link to comment
0 zoomer Posted April 20, 2023 Share Posted April 20, 2023 Interesting, thanks for trying. Will have to play with it .... EDIT : No luck, even when overwriting Wall Settings ? here is a test file .... (BTW, why is the file that large ? Not much to purge ...) Untitled 1.vwx Quote Link to comment
0 Tom W. Posted April 20, 2023 Share Posted April 20, 2023 I opened the file. Two of the WinDoor objects were already displaying Wall Closures. The remainder did not have 'Use Wall Closure' enabled in the Plug-in Object Options but when I enabled it they all displayed Wall Closures too... So all looks correct to me! 1 Quote Link to comment
0 zoomer Posted April 20, 2023 Share Posted April 20, 2023 Great ! Thanks ! That was it, didn't expect that also in Plugin Style Options ? Works now .... Quote Link to comment
0 zoomer Posted April 20, 2023 Share Posted April 20, 2023 BTW, we actually use Windows here, where the "Transom" is at the bottom of the Window, below the opening Sash. And even have two opening Sashes in a single Window, above each other. (Kind of a "Transom" with Sash and tilt function, above a tilt+turn Sash .... I think I have to switch to WinDoor again ? Would be nice if WinDoor Tool could grab and translate some of the basic Settings from a standard VW Window or Door .... Quote Link to comment
Matt Hagen
Hi,
Any ideas please??
Thanks
Matt Hagen
VW2023 SP3
Windows
15 answers to this question
