Matt Hagen
    36
Everything posted by Matt Hagen
  1. Thanks for that Patrick It looks like they suggested shutting down VW and starting again as the solution. I tried that and no change. restarted the computer even, no change
  2. Hi all last week my model started freaking out when I render using the shaded option. It looks like half the walls are missing when i render but I can still click on them Ive also noticed in wireframe, what looks like 3D loci points are HUGE VW 2022 SP 1 Any ideas please? 48 Ardern Ave REV v2022.vwx
  3. Is there anyway to show the 'reverse id' on a detail callout? ie, to show what cross-section and page it is referenced from?
  4. Thanks all. I will try the data tags. File attached as requested 31 Mariners Cove, McDonald House.vwx
  5. Seems strange that the eyedrop can change the default Class setting not just the item you apply it to
  6. Is anyone else having issues with window ID's showing up reversed on the elevation viewports when using WinDoor? When I go to the floor plan layer in the model it shows correctly. Ive attached two images, screenshots, one of the viewport with the reversed ID, the other of the model showing the correct ID orientation.
  7. Clumsy fingers are always a possibility although Ive never had it happen before and i don't 'nudge' objects. I will pay more attention and see if it is something like that. Thanks Pat
  8. Is anyone else having issues with the default class changing to random classes? Typically I work in 'none', then change as required but in the last week I've noticed the class changes to all sorts of random classes with no warning. Im using VW 202-SP 3 windows Thanks Matt Hagen
  9. Thanks Zoomer. I tried an earlier backup file also. It had the same result
  10. Hi I was rendering a file and Vectorworks crashed. Now when I open the back up file, it almost opens then crashes again. Any ideas on how to stop this please?Victoria St Hotel v3 v2021-Backup-20201126092852.vwx
  11. Thank you so much. Any chance you can apply that fix to the other 3 floors Ive attached this time please? BLK 27 - Level 1.dwg BLK 27 - Level 2.dwg BLK 27 - Level 3.dwg
  12. In trying to import a DWG file, the cladding tags are importing as symbols and changing the last letter/number in each tag to a different font and italics. Is there a way to ungroup all the symbols so I can change the text style and font type or an import setting I can change? BLK 27 - Ground Floor.dwg BLK 27 - Ground Floor.dwg
  13. Is there a way to extend the stair handrail at the landing? Under the OIP it gives the option to extend at the top, and at the bottom, but not at the midfloor Thanks
  14. Excellent, thats solved the DWG export lag thank you. When I originally set up the WinDoor schedule it had about 40 copies of each window/door, so I was trying different ways to sort it. Thats why there are so many windoor schedules
  15. Exporting to DWG is still taking forever. It seems sheet A601 & A009 are part of the issue (Level 2) When I export, it gets stuck at 9%
  16. Thanks Mihail, Ive assigned the floor slabs to BASEFLOOR and SLAB but they still arent showing up in the IFC model. When I reimport the IFC model into Vectorworks it comes up with the following:
  17. Thanks for the help guys I've changed to the 2x3 format and its improved. The floors still dont show though. They are not extrudes
  18. Exporting to Revit comes up with random lines. Possibly my export settings?
  19. Im trying to export to the above formats PDF takes literally FOREVER. I have to leave it over night. The Export to DWG, even sheet by sheet works on some sheets but seems to hang at 9% on Sheet A009. Exporting to IFC wont export the slab levels or windoor elements. It doesn't seem like a complicated file Am I missing something here? MATT HAGEN Vectorworks 2020 SP 3.1 Windows 10 Pro Dell Precision Tower 36020, Intel i7, 32G RAM 1050 Village Green.vwx
  20. Thanks Pat. Im using the tools/create report, preformatted report, then Windoor but cannot find how to edit the criteria. Can you direct me how to do this please? Ignore this. Sorted. Thanks
  21. Ive exported a record and placed on the sheet for Windoor doors and windows, all layers. Placed on the sheet and when it has multiple records of every item. If I select the item (G2-W01 for example) in the schedule, all records point to the same item. Any ideas please? Window Schedule.pdf
  22. Thanks Nina. That seems like a pretty accurate assessment. The Vectorworks file was new when i imported the DWG and I late added the Floor Plans. For future reference, is there a better way I should have gone about it? Thanks again for your help
  23. objects arent too far from internal origin. Ive uploaded the file in the hope it will help... Thank you _S1-21_27_St_Lukes.vwx
