Miss
11 -
Reputation
0 NeutralPersonal Information
Location
United Kingdom
Recent Profile Visitors
Hello, I'm having a problem with extruding my 2d circles, as you can see they are extruding upwards is there any way I can change the direction of the extrusion? I want the direction of the extrusion to be facing towards me if that makes sense. Please help, thank you
As you can see the walls have separated and I can't render them with any texture although the wall on the right is fine? The walls look fine in top plan. Can someone please help? Thank you
Nevermind I have done it, the offset was just off!
I have dragged it out and inserted it into the wall but it isn't doing anything? Not sure what Im doing wrong
This is what's coming up on OIP I don't see anything with it being in a wall or not. But there is a wall there and the door is inserted in the wall connecting to the windows.
Ok so after putting the door into a different class (it was in the walls class before) its done something but not what I wanted it to do?
So I have added textures to walls but it has also added it to the door? How do I fix this? Thank you in advance
Okay I will try that. Thank you. As you can see in the first image, the left side windows are in walls, I used the mirror tool to do the same on the right side but I'm guessing the walls won't get mirrored, only the windows do?
Thank you so much that seemed to work! I've been trying for over an hour haha! I had another question, im trying to put in a slab into one of the floors but I think due to my windows not joining im unable to do so. Is there a way to join up these windows, I have tried adding 'corner window' and corner post but It's not doing anything really. Thank you
Hi, I'm new to Vectorworks and im slightly confused. I am trying to fill a solid colour to my walls but the only thing that is happening is the outline of the walls is getting coloured (I will attach a image below) not sure what im doing wrong - any help would be appreciated. thank you.
