Neil Barman
Vectorworks, Inc Employee
    746
Everything posted by Neil Barman
  1. It’s funny you mention that @rgcn because I have noticed the exact same thing with my 3D Connexion Spacemouse. I didn’t have this connection “hiccup” in (low) Sierra but I do see it in High Sierra. It’s not surprising to hear it’s occurring for some people in Mojave. My hope is that Apple has provided enough information to the companies that make external devices so that those companies can update their device drivers as needed. Personally I’m in no hurry to upgrade my Mac OS to 10.14 Mojave... I have yet to see anything listed for Mojave’s new features and enhancements that is mission critical for getting my work done.
  2. @Jeremiah Russell Could you post that 2D version of the window you showed me early, so that this request had the appropriate visual aids? It would also be great to see a photograph of one of these windows in real life. Thanks!
  3. I would recommend exploring Collada exports further. This is how I have exported in the past to Sketchup (and other applications) and the recipients have reported the best results with Collada files. I just tried a Collada export again and it worked without issue, similar to @barkest. A folder is created and within it is a .dae file of my Vectorworks model. That .dae file imports into Sketchup fine.
  4. That is what I meant @Nicolas Goutte, yes. Thank you for clarifying. Since @Andrew Davies had asked about the plan for VW2018 and Mojave, I thought he might like to see the mention of the plan on that page. @bpbpbp As for discussion on the topic, that can certainly take place here of course. (And welcome to the Forum by the way!)
  5. For a little perspective... Launch day Mojave sounds like it needs a bit of work too. Read more here.
  6. At the moment that it is what's advised until Vectorworks can be confirmed compatible with the new Mac OS. I know how tempting and easy Apple makes it to upgrade, but it doesn't hurt to wait a bit to ensure compatibility before upgrading the OS.
  7. While @RGyori is correct that the most likely culprit is Vectorworks and Mac OS incompatibility, I don't believe VW2018 and VW2019 are confirmed compatible with Mac OS Mojave just yet. The official Mojave compatibility article can be found here. And if you need them, instructions on how to downgrade from Mojave to High Sierra are here. Older versions of Vectorworks (and other software that is out of its development cycle and that relies on internal components of the Mac OS) are not typically updated to run on newer Mac operating systems. Apple often changes the Mac OS enough "under the hood" from one OS to the next that trying to update an old version of software for a new OS can be a tremendous amount of work, if it's even possible at all.
  8. @Andrew Davies I just happened upon this comment of yours about Vectorworks Cloud Services. I hope you’ve had a chance to check it out since you posted. Cloud Services is actually great for individual users, because it’s like you have a second computer available to render your sheet layers. It does quite a bit more too. The descriptions along the bottom of the login page help explain what one can use it for. If you haven’t given it a good look, I encourage you to do so... It can add some rather interesting abilities to your workflows.
  9. @Aspect_Design If you are indeed still running VW2018 SP1 as your forum signature states, it would be good to update to SP4.
  10. Welcome @cleonidas! While I don't know of any in-person training in Seattle per se, I can recommend that you start out by doing relevant the Getting Started Guides here. These will give you a good introductory knowledge to using Vectorworks. Another great head start into using Vectorworks for Entertainment and Events is the Spotlight Virtual Training that Vectorworks itself offers. Keep an eye on the training calendar for upcoming dates. I have done the course myself and it's superb. In addition to the training above, another very good resource to have on hand is the Entertainment Design manual by @Kevin Allen. I hope that information helps. -Neil
  11. @David Poiron Can you tell what that tag refers to in your particular file? That is, what objects are similarly tagged?
  12. @dbrumbach I see what you mean... That is very interesting! I haven't used the workflow you describe myself, but I can totally see how being able to re-assign a Design Layer for an object within a group could indeed be useful. @JimW Might this "change" be a bug of sorts?
  13. @jeremybWhat a coincidence! I saw this very same thing yesterday in VW2016. Doing as @JimW suggested should work, as should simply dragging the bar at the bottom of the palette to stretch it taller.
  14. @hlagos If Ion’s suggestion didn’t work for you and you are not able to post the file, then I’m stumped too. I’d suggest testing with Vectorworks 2018 if you have access to it. Beyond that, if you still have tech support coverage through your distributor you could try running the issue past them.
  15. @baronjutter This sounds like the same thing you were dealing with in March. (Previous post is here.) What did the firm that created the file say about the doors/windows and the plug-in used when you contacted them?
  16. @baronjutter Is the firm that provided the file to you DIALOG, based in Vancouver, BC? If so, what did they say when you contacted them about the doors and windows?
  17. Interesting, @Ion. I hadn’t seen this one. @hlagos It would also be great if you filled in your signature here on the Forum so that others know what version of Vectorworks and hardware/OS you are using. This information often helps diagnose issues. Thanks!
  18. When you say you “added dimensions to the annotation layer”, do you mean that you added dimensions in the Viewport’s Annotation space by right-clicking on the viewport, choosing Edit Annotations, then adding the dimensions “in” that space? If so, dimensions placed in the Annotation space of a Viewport should indeed “stick” the points where they were placed. They should not rotate or move, unless the Viewport in which they are placed moves. Might you be able to post the Vectorworks file so we can take a look at it? There may be a technique used that isn’t apparent based on your description of what is occurring.
  19. Welcome to the Forum @rosebud!
  20. @Jainsworth In case it helps, I've also compiled some additional information on the topic at Paxar's support site here. The information consists of Vectorworks-made videos and a number of my own findings, noted as I was learning to use the new Title Block Borders. The new TBBs took a little bit of getting used to and experimenting with, but they are very much worth the effort IMO.
  21. I have appreciated this first hand. I submitted a request for commercial restaurant equipment, along with some relevant links & info, and the content team did a super job of creating great objects in a shorter time frame than I'd ever seen. I then used a number of the objects in a restaurant design I was working on at the time. The objects made my work look good and be more accurate. The client was impressed and was able to visualize his future kitchen far better. That's just one of the many aspects of Service Select that matters to me.
  22. Actually, in case it hasn't been communicated with you, there are other advantages to Service Select beyond just monetary savings. More details can be found here. Our clients seem to appreciate them, especially the Priority Technical Support. I suppose this is a personal thing, based on one's workflows and methods. yes, the new Title Block Border tool a bit of learning, but I have found the results to be worth the effort. To each their own though, as we all have different workflows and ways of using the software. Then it sounds like perhaps ending your Service Select when you retire makes sense. (Being an Architect though, will you ever really get to retire? 😉) For what it's worth, we recently had a client retire and he too discussed with us what his best course of action would be. (We actually love these chats because each person's case is unique.) In his case, he opted to continue his Service Select because he could foresee still doing a few casual projects per year, and imagined actually having more time and opportunity (than when he was practicing professionally) to use and explore the software. (As for Adobe's "rental" model, I hear you. As my former life was as a photographer, and I'd used Photoshop since v2 -not CS2, but v2-, I simply couldn't get behind Adobe's switch to CC. After using some alternatives, I have been using Affinity's Photo and Designer applications for a couple of years and their purchase model works for me.)
  23. Well put @Tom Klaber. Perhaps, but I suspect it's more that you are in the minority of being vocal about liking the Service Select maintenance program. If that's the case, I'll add my voice to yours... I vastly prefer owning Vectorworks with Service Select vs owning Vectorworks without Service Select. I too believe in contributing to the the continued development of the software. And, for what it's worth, I review the new features & improvement list each year and do incorporate at least a few new techniques to my skill set. My kids seem to appreciate that because it makes me more efficient... which means I get to spend a bit more time with them. My design clients seem to like the applicable new features/improvements that I incorporate too because it typically means they reap the benefits of my improved workflows. I've found that, when I speak with the "doubters", the vast majority of them realize the advantages of Service Select. Most understand and agree that dropping Service Select really only makes sense for someone who is retiring and won't be doing any paid work any more.
  24. @richardavatarThen, as you suggest later, it sounds you might be using a 3D navigation tool in a different Mode. This one is a personal preference, and somewhat related to the kind of work one does. For me, doing more architectural design work, I haven't wanted or needed Roll so far. I suppose if I was working on industrial design or set design, I would use Roll to get a better perspective on what I was creating. This could very well be. First, try @Andy Broomell's suggestion and let us know how it goes. If that doesn't help: 1) What tool are you using when you are in the "3D Mode" you are referring to? I am guessing it's the Flyover Tool, but I'm hoping you can confirm this. 2) Which Mode of the Flyover Tool is enabled in the Mode Bar? (There is a chance that if your objects are drawn away from "Origin", and your Mode is set to Active Layer Plane Origin Mode, this would cause you to, understandably, rotate around based on a point that is far from your objects.)
